[postgis-users] Fw: please help me about postgis
Shoaib Burq
shoaib at nomad-labs.com
Sun Jan 21 02:55:01 PST 2007
Alireza,
There is no need to specify x and y data values explicitly. The
AddGeometryColumn() takes care of it. If you need a table with point
data then do something like:
CREATE TABLE test
id integer NOT NULL,
name varchar(128),
CONSTRAINT test_pk PRIMARY KEY (id)
WITHOUTOIDS;
SELECT AddGeometryColumn('test', 'test_geom', 4326, 'POINT', 2 );
have a read of this
http://postgis.refractions.net/docs/ch04.html#id2837854 for a detailed
explanation of the process.
hope this helps
Shoaib
http://geospatial.nomad-labs.com
On 1/21/07, alireza ghahremanian <mat2ag at yahoo.com> wrote:
> I have a table like this:
> CREATE TABLE test
> x double precision,
> y double precision,
> WITHOUT OIDS;
> which contains some coordinates (x,y) of a track now I want to insert a geometry entry from this data in another table with a SELECT command something like this
> SELECT GeomFromText('LINESTRING(x y)') FROM test;
> but it does not work please help me. I should note that the data in table test will update every 5 sec. so I must my geometry tables with respect to test table data.
> with special thanks
> ____________________________________________________________________________________
> Food fight? Enjoy some healthy debate
> in the Yahoo! Answers Food & Drink Q&A.
> http://answers.yahoo.com/dir/?link=list&sid=396545367
> Dear Sandro Santilli
> Yahoo! Music Unlimited
> Access over 1 million songs.
> http://music.yahoo.com/unlimited
> postgis-users mailing list
