[postgis-users] Fw: please help me about postgis
alireza ghahremanian
mat2ag at yahoo.com
Sun Jan 21 03:18:48 PST 2007
I need create a line from this point which are dynamically updated so the line should be updated.
----- Original Message ----
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Cc: alireza ghahremanian <mat2ag at yahoo.com>
Sent: Sunday, January 21, 2007 2:24:25 PM
Subject: Re: [postgis-users] Fw: please help me about postgis
Alireza,
There is no need to specify x and y data values explicitly. The
AddGeometryColumn() takes care of it. If you need a table with point
data then do something like:
CREATE TABLE test
id integer NOT NULL,
name varchar(128),
CONSTRAINT test_pk PRIMARY KEY (id)
WITHOUTOIDS;
SELECT AddGeometryColumn('test', 'test_geom', 4326, 'POINT', 2 );
have a read of this
http://postgis.refractions.net/docs/ch04.html#id2837854 for a detailed
explanation of the process.
hope this helps
Shoaib
http://geospatial.nomad-labs.com
On 1/21/07, Shoaib Burq <saburq at gmail.com> wrote:
> The table you created is not spatial. to make it spatial you need to
> add a spatial column to it using AddGeometryColumn() function.
> There is no need to specify x and y and explicitly. The
> CREATE TABLE test
> name varchar(128),
> WITHOUTOIDS;
> have a read of this
> hope this helps
> Shoaib
> On 1/21/07, alireza ghahremanian <mat2ag at yahoo.com> wrote:
> > I have a table like this:
> > CREATE TABLE test
> > x double precision,
> > y double precision,
> > WITHOUT OIDS;
> > which contains some coordinates (x,y) of a track now I want to insert a geometry entry from this data in another table with a SELECT command something like this
> > SELECT GeomFromText('LINESTRING(x y)') FROM test;
> > but it does not work please help me. I should note that the data in table test will update every 5 sec. so I must my geometry tables with respect to test table data.
> > with special thanks
> > ____________________________________________________________________________________
> > Food fight? Enjoy some healthy debate
> > in the Yahoo! Answers Food & Drink Q&A.
> > http://answers.yahoo.com/dir/?link=list&sid=396545367
> > Dear Sandro Santilli
> > Yahoo! Music Unlimited
> > Access over 1 million songs.
> > http://music.yahoo.com/unlimited
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
