[postgis-users] Fw: please help me about postgis
Shoaib Burq
shoaib at nomad-labs.com
Sun Jan 21 03:34:33 PST 2007
Ah sorry... I missread you email must have been sleeping...
To create a linestring you need at least two points.
What is the error you get?
On 1/21/07, Shoaib Burq <shoaib at nomad-labs.com> wrote:
> Ah sorry... I miss read you email must have been sleeping...
> to create a linestring you need atleast two points.
> On 1/21/07, alireza ghahremanian <mat2ag at yahoo.com> wrote:
> > I need create a line from this point which are dynamically updated so the line should be updated.
> > ----- Original Message ----
> > From: Shoaib Burq <saburq at gmail.com>
> > To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> > Cc: alireza ghahremanian <mat2ag at yahoo.com>
> > Sent: Sunday, January 21, 2007 2:24:25 PM
> > Subject: Re: [postgis-users] Fw: please help me about postgis
> > Alireza,
> > There is no need to specify x and y data values explicitly. The
> > AddGeometryColumn() takes care of it. If you need a table with point
> > data then do something like:
> > CREATE TABLE test
> > id integer NOT NULL,
> > name varchar(128),
> > CONSTRAINT test_pk PRIMARY KEY (id)
> > WITHOUTOIDS;
> > SELECT AddGeometryColumn('test', 'test_geom', 4326, 'POINT', 2 );
> > have a read of this
> > http://postgis.refractions.net/docs/ch04.html#id2837854 for a detailed
> > explanation of the process.
> > hope this helps
> > Shoaib
> > http://geospatial.nomad-labs.com
> > On 1/21/07, Shoaib Burq <saburq at gmail.com> wrote:
> > > The table you created is not spatial. to make it spatial you need to
> > > add a spatial column to it using AddGeometryColumn() function.
> > > There is no need to specify x and y and explicitly. The
> > > CREATE TABLE test
> > > name varchar(128),
> > > WITHOUTOIDS;
> > > have a read of this
> > > hope this helps
> > > Shoaib
> > > > I have a table like this:
> > > > CREATE TABLE test
> > > > x double precision,
> > > > y double precision,
> > > > WITHOUT OIDS;
> > > > which contains some coordinates (x,y) of a track now I want to insert a geometry entry from this data in another table with a SELECT command something like this
> > > > SELECT GeomFromText('LINESTRING(x y)') FROM test;
> > > > but it does not work please help me. I should note that the data in table test will update every 5 sec. so I must my geometry tables with respect to test table data.
> > > > with special thanks
> > > > ____________________________________________________________________________________
> > > > Food fight? Enjoy some healthy debate
> > > > in the Yahoo! Answers Food & Drink Q&A.
> > > > http://answers.yahoo.com/dir/?link=list&sid=396545367
> > > > Dear Sandro Santilli
> > > > Yahoo! Music Unlimited
> > > > Access over 1 million songs.
> > > > http://music.yahoo.com/unlimited
> > > > postgis-users mailing list
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Expecting? Get great news right away with email Auto-Check.
> > Try the Yahoo! Mail Beta.
> > http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
