[postgis-users] How to insert the geometry field of a record with trigger and function
Veronique Chaffard
Veronique.Chaffard at hmg.inpg.fr
Wed Jan 24 03:40:21 PST 2007
I would like to insert the geometry field of a record by using a trigger
and a fonction, after the insertion of the other fields;The X and Y
coordinates are saved into 2 fields: LAT and LONG. The geometry field
type is a point.
My table is declared as:
CREATE TABLE TEST (
ID serial not null,
NOM VARCHAR(50) not null,
LONG FLOAT8 not null,
LAT FLOAT8 not null,
constraint PK_TEST primary key (ID)
SELECT AddGeometryColumn('','test','geom','-1','POINT',2);
Could you help me ?
Thanks in advance.
