[postgis-users] Starting the postmaster version8.2: pg_ctl <->postmaster
Steven De Vriendt
gisaalter at gmail.com
Fri Jan 26 09:35:18 PST 2007
Regina,
Thanks for your reply ! No I'm not running on Linux.
Got the problem solved though, funny, I've added the PGDATA
system variable including my data directory and everything was
working fine. I've I used the -D flag including my data directory
it didn't work...
Regards,
Steven
PS: Feeling kind of guilty now, you give me so much support lately :-)
thanks for that !
On 1/26/07, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Are you running on Linux? If you are, it looks like you are missing the
> start command. I think the syntax is
> /usr/local/pgsql/bin/pg_ctl start -l logfile -D /usr/local/pgsql/data
> according to the
> http://www.postgresql.org/docs/8.2/interactive/server-start.html
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net on behalf of Steven De
> Vriendt
> Sent: Thu 1/25/2007 9:25 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Starting the postmaster version8.2: pg_ctl
> <->postmaster
> Hi,
> I've upgraded postgres & postgis to the latest version available.
> I used to start the postmaster with the -i flag and -D- flag to
> be able to connect from outside.
> I see there's no postmaster.exe in version 8.2 of postgresql,
> so I use this command: pg_ctl -D "<mydatadirectory>" start.
> Yet, I can't connect to my db.
> Can someone confirm me this is the way to start the postmaster
> in 8.2 ?
> Regards,
> Steven
> The substance of this message, including any attachments, may be
> confidential, legally
> privileged and/or exempt from disclosure pursuant to Massachusetts
> law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and
> delete the material from any computer.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070126/7c05d523/attachment.html>
