[postgis-users] Updating to 1.2.0 on Win gives Linux error?
Barend K=?ISO-8859-1?B?9g==?=bben
kobben at itc.nl
Mon Jan 29 03:47:04 PST 2007
Thanks Mark, I got it working quite quickly, using your secons option. Just
had to figure out that I needed the geometry_columns table from the old one
and could use the spatial_ref_sys from the new one (as long as its not
customized).
I put it together in a readME file for our students as follows:
Assuming that you have installed PostGIS on a new host <host_of_new_install>
and the old PostGIS on <host_of_old_install>, then:
1.
a) Create a new PostGIS-enabled database of the same name under
PostgreSQL 8.2.
b) Delete/drop the 'geometry_columns' table
c) Keep the new PostGIS installed table spatial_ref_sys (it might have
updates coming from a PROJ4 update); Only if you customized your
spatial_ref_sys table in your old DB, delete the one in this new DB.
2.
a) Use pg_dump with the -Fc argument to create a custom format dump of your
entire old database:
pg_dump -h <host_of_old_install> -U <username> -Fc -f myDB.backup -i -C
<myDB>
b) Use pg_restore with the -l option to create a text file containing a
list of the contents of your dump file:
pg_restore -h <host_of_new_install> -U <username> -f toc.list -l myDB.backup
c) From this text file, remove everything that isn't a reference to any
of your tables, indices or the geometry_columns table.
If you did NOT have a customized spatial_ref_sys table (and therefore
deleted it in 1c), make sure to also delete all references to that.
d) Restore your dump file into the new PostgreSQL 8.2 database using
the -L option to specify a list of items to restore:
pg_restore -h <host_of_new_install> -U <username> -L toc.list -e -C -Fc -d
<myDB> myDB.backup
