[postgis-users] Problem With Geometries and a View
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Tue Jan 30 07:19:42 PST 2007
On Tue, 2007-01-30 at 10:47 -0300, Leonardo Mateo wrote:
(cut)
> - Then I try to select the extent of these points with:
> [CODE]
> select extent('the_geom') from geom;
> [/CODE]
> And I got this error:
> ERROR: parse error - invalid geometry
> The weird thing is that if I insert that SELECT sentence into another
> table and create a view from that table with something like this:
> [CODE]
> create view geom as Select * from <newtable>
> [/CODE]
> The extent is selected properly.
> What am I doing wrong? It's driving me nuts.
> Thanx a lot in advance.
Hi Leonardo,
The extent() function is an aggregate, and so requires a column
reference as opposed to a string. So your select should not have
apostrophes around the argument to the extent() function and should look
like this:
select extent(the_geom) from geom;
(FWIW I don't see a column called "the_geom" in your view; you may need
to use AS to create an alias for your GeomFromText() calculation).
Kind regards,
Mark.
