[postgis-users] grouping points by time offset
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at gmail.com
Sun Jul 1 06:05:07 PDT 2007
Hi Kurt, can you send me some example data that I can use to test the
function?
Rodrigo.
On 7/1/07, Kurt Schwehr <schwehr at ccom.unh.edu> wrote:
> Hi All,
> This is only sort of a postgis question, but I figured I'd try here
> in addition
> to the postgres newsgroup.
> I am pretty new to SQL and having trouble trying to formulate a query
> from what I have been reading in a couple of books (and got a
> suggestion from a friend that included cursors and is totally over my
> head). I would really appreciate any help getting this figured out.
> I am trying to group track positions from a ship into sections split
> by gaps of no recorded position from a particular ship for a period of
> time (say 60 minutes). I have a table "position_reports" something
> like this:
> key SERIAL PRIMARY KEY, ship_id INTEGER, position GEOMETRY, received
> TIMESTAMP, received_sec INTEGER
> position is a postgis POINT. The received_sec is the seconds since
> the epoc from the original logs that I have converted to a TIMESTAMP.
> Figure this query might be easier with one over the other?
> The goal is to be able to generate LINESTRINGs from each ship by time
> block that I record the ship. Right now, I end up doing a MakeLine
> for each ship which joins different passes of the ship through an area
> (which has ships flying over land quite frequently :)
> 1 123 someXY 2007-Jan-05 12:01
> 2 123 someXY 2007-Jan-05 12:04
> 3 123 someXY 2007-Jan-05 12:13
> # more than 60 minutes gap, so split groups here
> 4 123 someXY 2007-Jan-05 15:23
> 5 123 someXY 2007-Jan-05 15:46
> 6 123 someXY 2007-Jan-05 15:53
> 7 123 someXY 2007-Jan-05 16:01
> Thanks,
> -Kurt
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070701/b0843dc5/attachment.html>
