[postgis-users] insert interactively asc or text files
Chetan Tiwari
chetan.tiwari at gmail.com
Wed Jul 4 09:42:45 PDT 2007
Hi Pere
I have a little perl script that reads CSV files uploaded via a browser and
inserts the data into a table in postgres. I'll be happy to share that with
you. It's setup to run with active perl and apache on windows, but it would
be fairly easy to tweak it to your system setup.
- Chetan
On 7/4/07, pere roca <peroc79 at gmail.com> wrote:
> Hi everybody,
> I just was wondering if there is some tool to insert automatically data
> from a .asc or .csv or text file (just X,Y and thematic data) to PostGIS
> (something similar to shp2pgsql.exe).
> What I want to do is that after a user inserts a file in our server,
> automatically this file is inserted in someway to PostGIS. How would you
> do
> it?
> Thanks!
> Pere
> View this message in context: http://www.nabble.com/insert
> -interactively-asc-or-text-files-tf4022887.html#a11426251
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Chetan Tiwari, Ph.D. (ABD)
Dept. of Geography, The Univ. of Iowa
316 Jessup Hall, Iowa City, IA 52242
Ph. (319) 335-0165 Fax (319) 335-2725
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070704/bad55dd6/attachment.html>
