[postgis-users] Mezogis is closing when using a database
alex bodnaru
alexbodn at 012.net.il
Wed Jul 4 23:57:40 PDT 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hello daniela,
i have made a few changes to stock mezogis-0.1.5 to support current
psycopg2. now i have no problem with your data on my debian machine.
the working mezogis has been sent to you privately, and the patch has
been sent to frederic back too.
i would be interested if it works for you now.
good luck,
alex
Daniela Stärke wrote:
> Hi Alex,
> wow I probably found a bug, I am amazed.
> OK I made a new database which some geometrical form in it and tried to start it with mezzogis. But as expected I received the same messages as before.
> In the appendix of this email you find the dump-data of my database. It is just a simple one.
> Here are the neccessary information to start the database:
> the user: testuser ,
> password: das ,
> database: neutest ,
> port: 5340
> thanks for your help
> Daniela
>> daniela,
>> it really seems to be a bug in mezogis, and you quite clearly described
>> it.
>> somehow, the name of a column gets being used in an incorrect way.
>> i would take a look at the code later, and a subset of your data would
>> be necessary.
>> cheers,
>> alex
>>> Hi alex,
>>> there is a connection to the db available. I also had reinstalled
>> Mezogis at the beginning of this week. On my linux I have this versions of gtk
>> 1.2.10 as well as gtk2 2.10.6.
>>> loading the db is without problems, but when I want to start it, whether
>> with doubleclick, the SQL-commant "SELECT * FROM...." i get first this:
>>> /usr/local/lib/python2.5/site-packages/mezoGISlib/_canvas.py:524:
>> GtkWarning: Using Cairo rendering requires the drawable argument to
>>> have a specified colormap. All windows have a colormap,
>>> however, pixmaps only have colormap by default if they
>>> were created with a non-NULL window argument. Otherwise
>>> a colormap must be set on them with gdk_drawable_set_colormap
>>> self.ctx = self.pixmap.cairo_create()
>>> and then the part, which was in my last post.
>>> But I found out, that when I select not all columns of the db, the
>> colums are printed.
>>> Just when I want to use the column "color_map" I receive the message
>> above.
>>> I also checked the source code, but I don't know, what to do with it, or
>> in it.
>>> Do you have any idea???
>>> bye
>>> Daniela
>>>>> hi daniela,
>>>> this also shows an incompatibility of mezogis with your installed gtk.
>>>> should you think it's helpful, i have reinstalled latest mezogis and
>> i'd
>>>> give a try to connect toyour db, if possible.
>>>> alex
>>>>> Thank you alex for your help.
>>>>> I commented the part of the cursor collection out, and now MezoGIS is
>>>> not closing when opening the DB (:D:D:D), but now I receive the
>> following
>>>> messages (:(:(:() :
>>>>> Traceback (most recent call last):
>>>>> File
>> "/usr/local/lib/python2.5/site-packages/mezoGISlib/_pane_db.py",
>>>> line 522, in __on_doubleclick
>>>>> ##self.pgbutler.runQuery('SELECT * FROM %s'%table.getSQL())
>>>>> File
>> "/usr/local/lib/python2.5/site-packages/mezoGISlib/_guicore.py",
>>>> line 397, in runQuery
>>>>> #self.showResults(cursor, query, layer, resultset, tablelist)
>>>>> File
>>>> line 431, in showResults
>>>>> #mapview = openMapView(layer.resultset)
>>>>> File
>>>> "/usr/local/lib/python2.5/site-packages/mezoGISlib/_guiwindows.py",
>> line 33, in openMapView
>>>>> #m = MapWindow(resultset)
>>>>> File
>> line 139, in __init__
>>>>> #self.canvas = MapCanvas()
>>>>> File "/usr/local/lib/python2.5/site-packages/mezoGISlib/_canvas.py",
>>>> line 86, in __init__
>>>>> #self.__createNewCanvas()
>>>> line 524, in __createNewCanvas
>>>>> #self.ctx = self.pixmap.cairo_create()
>>>>> cairo.Error: NULL pointer
>>>>> I also tried the same strategy like before, but this will not really
>>>> work, because I get then the same massage.
>>>>> So has anyone any idea???
>>>>> Thanks in advance.
>>>>> Daniela
>>>>>> hi daniela,
>>>>>> i have previously played with mezogis a little.
>>>>>> it might be, that under the condition of your work mezogis tried to
>>>> open
>>>>>> a non existing cursor.
>>>>>> as a start point, i'd remove the calling code to the cursor
>> collection
>>>>>> and inquire further.
>>>>>> hth,
>>>>>> alex
>>>>>>> Thanks for the information. I downloaded the newest version of wxGTK
>>>>>> (2.8.4), but the problem is still there.
>>>>>>> After trying to open a geo-database with MezoGIS the program is
>> still
>>>>>> closing and on the shell there is this,
>>>>>>> /usr/local/lib/python2.5/site-packages/mezoGISlib/_guiwindows.py:80:
>>>>>> GtkWarning: gdk_colormap_get_screen: assertion `GDK_IS_COLORMAP
>> (cmap)'
>>>> failed
>>>>>>> CursorCollection.xpm["hand-open"])
>>>>>>> two times printed.
>>>>>>> I had the idea, that I could look in the source code of
>> _guiwindows.py
>>>>>> to see if there might be something missing or so, but in line 80
>> there
>>>> is no
>>>>>> 'gdk_colormap_get_screen' or 'GDK_IS_COLORMAP' written. Just the
>>>>>> CursorCollection.
>>>>>>> Is it possible, that the method 'gdk_colormap_get_screen'is not jet
>>>>>> written???
>>>>>>> Because when I use the search-function of the vim-editor I receive
>> the
>>>>>> message, that there is no 'gdk_colormap_get_screen' or
>>>> 'GDK_IS_COLORMAP'
>>>>>>> I really need some help.
>>>>>>> Thank you in advance for your attention in this matter.
>>>>>>> Daniela
> postgis-users mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iQCVAwUBRoyWY9pwN1sq38njAQLrIQP9GVGE5r66x/GBsfBcfQv5C+f88iebUorl
V0h7PcMPLyp84Q45K3nT5LREamWR+DZP46v1BR4GytPDgUHLu1LH3hOyJo/y0Mfx
TBfayb2F9+XSP+s4iGTT58/pTO9xU0fmhroghZkNO0XrsUhNGxrED0J3I3clsr27
1A+x2uosPSo=
=Cl6N
-----END PGP SIGNATURE-----
