[postgis-users] Large geometry issue
Martin Davis
mbdavis at refractions.net
Thu Jul 5 16:32:40 PDT 2007
No problem. Actually it's me being blind - I just saw the attachment
with the test data.
2530 vertices isn't a very big polygon. So this isn't a problem with
lots of holes or shells, it simply reveals that we're not extracting the
maximum possible performance from a querying involving comparing many
small geoms against a single large one. Stay tuned - hopefully we'll
have a better story for this shortly.
Martin
Gregory Williamson wrote:
> Martin,
> Sorry for the lack of coherence -- 2530 vertices in this test polygon
> ... it should be in the original posting I sent, an attached zip file
> with two tables; this is the single entry in the oli_req table. The
> other table has some 13000 rows of polygons which are either
> completely within or overlapping with the large poly.
> If you can't get at that let me know and I'll send you a copy ...
> Greg W.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net on behalf of
> Martin Davis
> Sent: Thu 7/5/2007 5:09 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Large geometry issue
> Greg,
> Can you elaborate on your statement "2530 in a sinlge polygon"? Do you
> mean holes or subPolygons in a MultiPolygon?
> Either way, currently JTS is not optimized for working with very large
> numbers of holes and sub-polygons. As Paul says, we are currently
> working on improving this. Hopefully we can at least match the
> performance of the Other DMBS(es) for this situation!
> Would it be possible for me to obtain this geometry for testing?
> Martin
> > Dear peoples,
> > I have a problem with a query that uses an absurdly large geometry
> > (2530 in a single polygon). This is srid -1 (part of a large test of
> > postgres vs some other database product). Everything has been vacuumed
> > and analyzed.
> > The initial search to find candidates in a target table is quite fast:
> > catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE
> > x.bbox && w.geometry AND x.id_as_int = 114672;
> > count
> > 13168
> > (1 row)
> > Time: 9.472 ms
> > Trying to get the list narrowed to geometries that are completely
> > contained by the requested shape is slow:
> > x.bbox && w.geometry AND distance(x.geometry,w.geometry) = 0 and
> > count
> > 1112
> > (1 row)
> > Time: 69277.780 ms
> > So I have two questions:
> > a) anything better to use than "distance(x,y) = 0) ? I tried
> > st_within -- it is about the same speed but returns no polys, which is
> > strange to me, but I also haven't looked at these in detail yet. For
> > example:
> > x.bbox && w.geometry AND st_within(x.geometry,w.geometry) and
> > count
> > 0
> > (1 row)
> > Time: 1173.185 ms
> > (same results with st_within(w.geometry,x.geometry):
> > x.bbox && w.geometry AND st_within(w.geometry,x.geometry) and
> > count
> > 0
> > (1 row)
> > b) anything I can do to speed things up ? I have tried boosting work
> > mem to 16 megs (from 1) and it made no apparent difference.
> > I have a self contained test case that shows the same behavior -- the
> > one large poly and all the candidates in another table. Apologies for
> > the size; hopefully it's not been mangled in the transfers.
> > Explain analyze of the sample (the sequential is sensible since there
> > is only one row in the table):
> > catest=# explain analyze select count(*) from wsc_candidates w,
> > oli_req x WHERE w.geometry && x.bbox AND
> > distance(w.geometry,x.oli_req_geom) > 0 AND x.oli_req_id = 114672;
> > QUERY PLAN
> > Aggregate (cost=20.28..20.29 rows=1 width=0) (actual
> > time=77232.858..77232.859 rows=1 loops=1)
> > -> Nested Loop (cost=0.00..9.30 rows=4389 width=0) (actual
> > time=6.389..77221.506 rows=12056 loops=1)
> > Join Filter: (distance(w.geometry, x.oli_req_geom) >
> > 0::double precision)
> > -> Seq Scan on oli_req x (cost=0.00..1.01 rows=1
> > width=40602) (actual time=0.007..0.009 rows=1 loops=1)
> > Filter: (oli_req_id = 114672)
> > -> Index Scan using wsc_c_spatial_ndx on wsc_candidates w
> > (cost=0.00..8.27 rows=1 width=109) (actual time=0.022..25.991
> > rows=13168 loops=1)
> > Index Cond: (w.geometry && x.bbox)
> > Filter: (w.geometry && x.bbox)
> > Total runtime: 77232.901 ms
> > (9 rows)
> > Time: 77233.773 ms
> > And for the real thing:
> > catest=# explain analyze select count(*) from wtm_sub_cell w,
> > order_line_item x WHERE w.geometry && x.bbox AND
> > distance(w.geometry,x.geometry) = 0 AND x.id_as_int = 114672;
> > QUERY
> > PLAN
> > Aggregate (cost=141.83..141.84 rows=1 width=0) (actual
> > time=77457.587..77457.588 rows=1 loops=1)
> > -> Nested Loop (cost=5.99..141.83 rows=1 width=0) (actual
> > time=15.682..77456.541 rows=1112 loops=1)
> > Join Filter: (distance(w.geometry, x.geometry) = 0::double
> > precision)
> > -> Index Scan using oli_id_ndx on order_line_item x
> > (cost=0.00..8.30 rows=1 width=383) (actual time=0.012..0.018 rows=1
> > loops=1)
> > Index Cond: (id_as_int = 114672)
> > -> Bitmap Heap Scan on wtm_sub_cell w (cost=5.99..132.97
> > rows=32 width=109) (actual time=2.988..21.796 rows=13168 loops=1)
> > -> Bitmap Index Scan on wsc_geom_idx1
> > (cost=0.00..5.98 rows=32 width=0) (actual time=2.828..2.828 rows=13168
> > loops=1)
> > Total runtime: 77457.633 ms
> > (10 rows)
> > Time: 77458.458 ms
> > The tables involved by size:
> > catest=# select count(*) from wsc_candidates;
> > count
> > 13168
> > (1 row)
> > Time: 2.586 ms
> > catest=# select count(*) from oli_req;
> > count
> > 1
> > (1 row)
> > Time: 0.193 ms
> > catest=# select count(*) from wtm_sub_cell;
> > count
> > 6399928
> > (1 row)
> > Time: 1776.508 ms
> > catest=# select count(*) from order_line_item;
> > count
> > 395921
> > (1 row)
> > Time: 176.083 ms
> > Many thanks for your time and bandwidth!
> > Greg Williamson
> > Senior DBA
> > GlobeXplorer LLC, a DigitalGlobe company
> > Confidentiality Notice: This e-mail message, including any
> > attachments, is for the sole use of the intended recipient(s) and may
> > contain confidential and privileged information and must be protected
> > in accordance with those provisions. Any unauthorized review, use,
> > disclosure or distribution is prohibited. If you are not the intended
> > recipient, please contact the sender by reply e-mail and destroy all
> > copies of the original message.
> > (My corporate masters made me say this.)
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
Martin Davis
(250) 383-3022
