[postgis-users] Large geometry issue
Pedro Doria Meunier pdoria at netmadeira.com
Fri Jul 6 00:01:16 PDT 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Just sharing my POV here...
My largest geometry has 138,796 vertices (with some, not many, holes)
and it's used daily as the base for comparing smaller polygons
(geofences) onto it. I've never experienced performance issues.
btw: I'm using postgis 1.1 on that server (yeah I know... I should
have upgraded by know... ;-) )
The platform it's running under is Fedora 6, 2GB of ram.
Kind regards,
Pedro Doria Meunier
Martin Davis wrote:
> No problem.  Actually it's me being blind - I just saw the
> attachment with the test data.
> 2530 vertices isn't a very big polygon.  So this isn't a problem
> with lots of holes or shells, it simply reveals that we're not
> extracting the maximum possible performance from a querying
> involving comparing many small geoms against a single large one.
> Stay tuned - hopefully we'll have a better story for this shortly.
> Martin
> Gregory Williamson wrote:
>> Martin,
>> Sorry for the lack of coherence -- 2530 vertices in this test
>> polygon ... it should be in the original posting I sent, an
>> attached zip file with two tables; this is the single entry in the
>> oli_req table. The other table has some 13000 rows of polygons
>> which are either completely within or overlapping with the large poly.
>> If you can't get at that let me know and I'll send you a copy ...
>> Greg W.
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net on behalf of
>> Martin Davis
>> Sent: Thu 7/5/2007 5:09 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] Large geometry issue
>> Greg,
>> Can you elaborate on your statement "2530 in a sinlge polygon"?  Do
>> you
>> mean holes or subPolygons in a MultiPolygon?
>> Either way, currently JTS is not optimized for working with very large
>> numbers of holes and sub-polygons.  As Paul says, we are currently
>> working on improving this.  Hopefully we can at least match the
>> performance of the Other DMBS(es) for this situation!
>> Would it be possible for me to obtain this geometry for testing?
>> Martin
>> > Dear peoples,
>> > I have a problem with a query that uses an absurdly large geometry
>> > (2530 in a single polygon). This is srid -1 (part of a large test of
>> > postgres vs some other database product). Everything has been
>> vacuumed
>> > and analyzed.
>> > The initial search to find candidates in a target table is quite
>> fast:
>> > catest=# select count(*) from wtm_sub_cell w, order_line_item x
>> WHERE
>> > x.bbox && w.geometry AND x.id_as_int = 114672;
>> >  count
>> >  13168
>> > (1 row)
>> > Time: 9.472 ms
>> > Trying to get the list narrowed to geometries that are completely
>> > contained by the requested shape is slow:
>> WHERE
>> > x.bbox && w.geometry AND distance(x.geometry,w.geometry) = 0 and
>> >  count
>> >   1112
>> > (1 row)
>> > Time: 69277.780 ms
>> > So I have two questions:
>> >   a) anything better to use than "distance(x,y) = 0) ? I tried
>> > st_within -- it is about the same speed but returns no polys,
>> which is
>> > strange to me, but I also haven't looked at these in detail yet. For
>> > example:
>> WHERE
>> > x.bbox && w.geometry AND st_within(x.geometry,w.geometry) and
>> >  count
>> >      0
>> > (1 row)
>> > Time: 1173.185 ms
>> > (same results with st_within(w.geometry,x.geometry):
>> WHERE
>> > x.bbox && w.geometry AND st_within(w.geometry,x.geometry) and
>> >  count
>> >      0
>> > (1 row)
>> >   b) anything I can do to speed things up ? I have tried boosting
>> work
>> > mem to 16 megs (from 1) and it made no apparent difference.
>> > I have a self contained test case that shows the same behavior --
>> the
>> > one large poly and all the candidates in another table. Apologies
>> for
>> > the size; hopefully it's not been mangled in the transfers.
>> > Explain analyze of the sample (the sequential is sensible since
>> there
>> > is only one row in the table):
>> > catest=# explain analyze select count(*) from wsc_candidates w,
>> > oli_req x WHERE w.geometry && x.bbox AND
>> > distance(w.geometry,x.oli_req_geom) > 0 AND x.oli_req_id = 114672;
>> > QUERY PLAN                                     >
>> >  Aggregate  (cost=20.28..20.29 rows=1 width=0) (actual
>> > time=77232.858..77232.859 rows=1 loops=1)
>> >    ->  Nested Loop  (cost=0.00..9.30 rows=4389 width=0) (actual
>> > time=6.389..77221.506 rows=12056 loops=1)
>> >          Join Filter: (distance(w.geometry, x.oli_req_geom) >
>> > 0::double precision)
>> >          ->  Seq Scan on oli_req x  (cost=0.00..1.01 rows=1
>> > width=40602) (actual time=0.007..0.009 rows=1 loops=1)
>> >                Filter: (oli_req_id = 114672)
>> >          ->  Index Scan using wsc_c_spatial_ndx on wsc_candidates
>> w > (cost=0.00..8.27 rows=1 width=109) (actual time=0.022..25.991
>> > rows=13168 loops=1)
>> >                Index Cond: (w.geometry && x.bbox)
>> >                Filter: (w.geometry && x.bbox)
>> >  Total runtime: 77232.901 ms
>> > (9 rows)
>> > Time: 77233.773 ms
>> > And for the real thing:
>> > catest=# explain analyze select count(*) from wtm_sub_cell w,
>> > order_line_item x WHERE w.geometry && x.bbox AND
>> > distance(w.geometry,x.geometry) = 0 AND x.id_as_int = 114672;
>> QUERY
>> > PLAN                                          >
>> >  Aggregate  (cost=141.83..141.84 rows=1 width=0) (actual
>> > time=77457.587..77457.588 rows=1 loops=1)
>> >    ->  Nested Loop  (cost=5.99..141.83 rows=1 width=0) (actual
>> > time=15.682..77456.541 rows=1112 loops=1)
>> >          Join Filter: (distance(w.geometry, x.geometry) = 0::double
>> > precision)
>> >          ->  Index Scan using oli_id_ndx on order_line_item x >
>> (cost=0.00..8.30 rows=1 width=383) (actual time=0.012..0.018 rows=1
>> > loops=1)
>> >                Index Cond: (id_as_int = 114672)
>> >          ->  Bitmap Heap Scan on wtm_sub_cell w  (cost=5.99..132.97
>> > rows=32 width=109) (actual time=2.988..21.796 rows=13168 loops=1)
>> >                ->  Bitmap Index Scan on wsc_geom_idx1 >
>> (cost=0.00..5.98 rows=32 width=0) (actual time=2.828..2.828 rows=13168
>> > loops=1)
>> >  Total runtime: 77457.633 ms
>> > (10 rows)
>> > Time: 77458.458 ms
>> > The tables involved by size:
>> > catest=# select count(*) from wsc_candidates;
>> >  count
>> >  13168
>> > (1 row)
>> > Time: 2.586 ms
>> > catest=# select count(*) from oli_req;
>> >  count
>> >      1
>> > (1 row)
>> > Time: 0.193 ms
>> > catest=# select count(*) from wtm_sub_cell;
>> >   count
>> >  6399928
>> > (1 row)
>> > Time: 1776.508 ms
>> > catest=# select count(*) from order_line_item;
>> >  count
>> >  395921
>> > (1 row)
>> > Time: 176.083 ms
>> > Many thanks for your time and bandwidth!
>> > Greg Williamson
>> > Senior DBA
>> > GlobeXplorer LLC, a DigitalGlobe company
>> > Confidentiality Notice: This e-mail message, including any
>> > attachments, is for the sole use of the intended recipient(s) and
>> may
>> > contain confidential and privileged information and must be
>> protected
>> > in accordance with those provisions. Any unauthorized review, use,
>> > disclosure or distribution is prohibited. If you are not the
>> intended
>> > recipient, please contact the sender by reply e-mail and destroy all
>> > copies of the original message.
>> > (My corporate masters made me say this.)
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Remi - http://enigmail.mozdev.org
iD8DBQFGjei82FH5GXCfxAsRAvrEAJ4zH5zZ+gmpIvCd8aO2rFkE6X+JZACePyPc
DEnZ/0ThENj9EEU3VJ4www8=
=Q8VC
-----END PGP SIGNATURE-----
