[postgis-users] (no subject)
Broun Uganda
tekuganda at hotmail.com
Mon Jul 9 10:30:51 PDT 2007
Dear all,A trying to write a trigger that would automatically create lines joining points in the sequence in which i insert them. If I insert point AA then BB then CC, i want lines drawn as AA-BB & BB-CC, Using the trigger below lines are drawn ( atleast i can see the gid in table links) without the geometry.May anyone advise me on this.Thank youCREATE OR REPLACE FUNCTION insert_new_links() RETURNS "trigger" AS 'DECLAREstartpoint geometry; endpoint geometry;BEGINstartpoint = asEWKT(NEW.the_geom) WHERE NEW.gid = NEW.gid;endpoint = asEWKT(NEW.the_geom) WHERE NEW.gid = NEW.gid+1;INSERT INTO links(the_geom)VALUES(MakeLine(startpoint, endpoint ));RETURN NEW; END' LANGUAGE plpgsql; CREATE OR TRIGGER insert_new_links_insert BEFORE INSERT ON nodes FOR EACH ROW EXECUTE PROCEDURE insert_new_links();Broun Uganda
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070709/ab1d1cbe/attachment.html>
