[postgis-users] Trigger to update lines using new points
Obe, Regina robe.dnd at cityofboston.gov
Wed Jul 11 07:48:20 PDT 2007
Are you trying to do a line segment each comprising of 2 points or a
continuous line segment comprising of the whole batch of points you are
loading?
Couple of things that strike me odd are
1) Seems like you would never have a record NEW.gid + 1 if you are doing
a FOR EACH ROW before insert since that row would not have been inserted
yet and both your start and end points are the same in your example
since you are reading from NEW.
2) I think for this case you should really be using an after insert
trigger so you are seeing the latest data.
3) There is no reason to do asEWKT since you want a geometry
4) If you want to draw a line comprising more than 2 points - e.g
containing the full batch of your inserts then you don't want to do a
row level trigger, but instead a per statement trigger.
Anyrate I would think your per row trigger function code should look
something like this
CREATE OR REPLACE FUNCTION insert_new_links() RETURNS "trigger"
 AS '
BEGIN
INSERT INTO links(the_geom)
    SELECT MakeLine(prevnode.the_geom, NEW.the_geom)
        FROM nodes As prevnode WHERE prevnode.gid = NEW.gid - 1;
RETURN NEW;
 END' LANGUAGE plpgsql;
CREATE OR  TRIGGER insert_new_links_insert
AFTER INSERT ON nodes
FOR EACH ROW
EXECUTE PROCEDURE insert_new_links();
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Broun Uganda
Sent: Tuesday, July 10, 2007 12:11 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Trigger to update lines using new points
Dear all,A trying to write a trigger that would automatically create
lines joining points in the sequence in which i insert them.
If I insert point AA then BB then CC, i want lines drawn as AA-BB &
BB-CC, Using the trigger below lines are drawn ( atleast i can see the
gid in table links) without the geometry. May anyone advise me on this.
Thank you
 AS 'DECLAREstartpoint geometry;
endpoint geometry;
BEGIN
startpoint = asEWKT(NEW.the_geom)  WHERE NEW.gid = NEW.gid;
endpoint = asEWKT(NEW.the_geom) WHERE NEW.gid = NEW.gid+1;
INSERT INTO links(the_geom)VALUES(MakeLine(startpoint, endpoint ));
RETURN NEW;
BEFORE INSERT ON nodes
FOR EACH ROW
Broun Uganda
Live Earth is coming.  Learn more about the hottest summer event - only
on MSN. Check it out!
<http://liveearth.msn.com?source=msntaglineliveearthwlm>
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070711/30729b1b/attachment.html>
