[postgis-users] RE: insert interactively asc or text files
Stephen Davies sdc at sdc.com.au
Wed Jul 11 16:53:27 PDT 2007
If you are using *NIX, you can add to the automation by configuring your
mail server to receive files via email and direct them to a program to
do the actual data insertion.
eg  add an alias entry like:
loascsv:|/usr/local/bin/loadcsv
Any email sent to loadcsv at your.domain will be directed to the
program/shell script /usr/local/bin/loadcsv.
HTH,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s).  No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting                            Voice: 08-8177 1595
Adelaide, South Australia.                             Fax: 08-8177 0133
Computing & Network solutions.                       Mobile:0403 0405 83
