[postgis-users] Re: Getting data from Archicad into Postgis
Stephen Souness
sounie at hotmail.com
Sat Jul 14 19:00:16 PDT 2007
I used the "AutoCad DXF to ESRI Shapefile Converter" downloaded from
http://www.happysquirrel.com/index.php?feature=dxf2shp
Obe, Regina wrote:
> What software are you using for conversion?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Stephen Souness
> Sent: Friday, July 13, 2007 12:13 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Getting data from Archicad into Postgis
> Hi all,
> This may be a weird question, but I'll ask away anyway.
> I want to set up a Postgis database to contain location information for
> a group of buildings.
> The architect involved in the project is using some software called
> Archicad.
> I have tried converting a DXF file to a polygon shapefile, but the
> resultant data had various shapes out of position relative to eachother.
> Has anyone tried something like this before, or can someone point out
> the obvious flaw in my idea?
> Stephen
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
