[postgis-users] Polygon and north pole
Jørn Vegard Røsnes jorn at spacetec.no
Mon Jul 16 04:30:10 PDT 2007
is it possible to insert polygons into PostGIS where the polygon "cross" the
north pole?
Example:
select isvalid('POLYGON((152.991022 78.938867,79.710092 68.321799,-50.514656
62.226884,-9.980464 56.376708, 152.991022 78.938867))');
ERROR:  isvalid:: operation not implemented - compile PostGIS with JTS or GEOS
support
Will it help to compile PostGIS with GEOS/JTS support?
cheers
Jørn Vegard Røsnes
