[postgis-users] You've found a bug!
John Cole
john.cole at uai.com
Tue Jul 17 15:16:25 PDT 2007
Geomunion works but is painfully slow (minutes rather than seconds). Any
suggestions on how to get a collect (or something similar) to work?
Thanks,
John
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Tuesday, July 17, 2007 2:42 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] You've found a bug!
That's strange. I never thought shape files ever supported geometry
collections. Are you sure that last time you ran it maybe your collect
returned all multipoint or multipolygons and now with a newer dataset your
have a mixed back resulting in one or more records being a
geometrycollection?
What happens when you replace collect with geomunion?
thanks,
Regina
_____
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of John
Cole
Sent: Tuesday, July 17, 2007 3:03 PM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] You've found a bug!
Running pgsql2shp with the following query on a tiger lkA table, I get a
notice that I've found a bug :-) This query worked with 8.1.
"select coalesce(fedirp || ' ', '') || fename || coalesce(' ' || fetype, '')
|| coalesce(' ' || fedirs, '') as name, case when substring(fename, '(Old)')
is not null then null else substring(fename,
'(?:I[[:space:]]?-?|Highway|Hwy|County[[:space:]]Road|Co[[:space:]]Rd|County
|State[[:space:]]Route|Parish|Parish[[:space:]]Road|S[[:space:]]R|C[[:space:
]]R|Sr|Co|Carretera|St[[:space:]]Rt|C Rd|Co
R|County[[:space:]]Route|Cr-?)+[[:space:]]?([[:digit:]]+)') end as hwy_num,
cfcc, transform(simplify(segmentize(transform(collect(the_geom), 1000000),
1), 3), 4326) as the_geom from TGR01001 where substring(cfcc,
'(A[456789])+') is not null group by cfcc, hwy_num, fedirp, fename, fetype,
fedirs order by cfcc desc"
Preparing table for user query... Done.
Initializing... type 'GEOMETRYCOLLECTION' is not Supported at this time.
The DBF file will be created but not the shx or shp files.
You've found a bug! (pgsql2shp.c:2869)
Thanks,
John
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the sender. This
message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070717/fc209336/attachment.html>
