[postgis-users] Performance Help
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Thu Jul 26 04:01:58 PDT 2007
On Thu, 2007-07-26 at 10:05 +0000, Alan Cunnane wrote:
> Apologies for that last email it was sent by accident.
> Here are a list of my table definitions:
> Table "bus_stops1"
> Column | Type | Modifiers
> stop_reference | character varying(12) | not null
> easting | integer | not null
> northing | integer | not null
> full_location | character varying(50) |
> east_north | geometry | not null
> Indexes:
> "bus_stops1_pkey" PRIMARY KEY, btree (stop_reference)
> "stops_distance1" gist (east_north) CLUSTER
> Check constraints:
> "enforce_dims_east_north" CHECK (ndims(east_north) = 2)
> "enforce_geotype_east_north" CHECK (geometrytype(east_north) =
> 'POINT'::text OR east_north IS NULL)
> "enforce_srid_east_north" CHECK (srid(east_north) = 27700)
> This table contains a list of bus stops, their full addresses and
> their coordinates. "Stop_reference" is a unique ID that each
> individual bus stops contains.
> Table "Routes1"
> service_id | integer | not null
> route_number | character varying(4) | not null
> Indexes:
> "routes1_pkey" PRIMARY KEY, btree (service_id)
> "routes1_route_number" btree (route_number)
> This table contains information about each route. A route is defined
> by each different bus number that travels that day. The service_id
> here is a unique number given to each trip every bus makes that day.
> For example "route_number 3" bus will have 40+ service trips each day
> from 7am to 11pm.
> Table "service1"
> arrival_time | time without time zone |
> depart_time | time without time zone |
> stop_order | integer | not null
> Indexes:
> "service1_service_id" btree (service_id)
> "service1_stop_order" btree (stop_order)
> "service1_stop_reference" btree (stop_reference)
> Foreign-key constraints:
> "service1_service_id_fkey" FOREIGN KEY (service_id) REFERENCES
> routes1(service_id)
> "service1_stop_reference_fkey" FOREIGN KEY (stop_reference)
> REFERENCES bus_stops1(stop_reference)
> The service1 table lists each of these service trips in detail.
> Showing the list of bus stops that each service uses along its route,
> the order in which the bus arrives at these stops and the time that
> the bus arrives and departs at these stops.
> Table "stop_link"
> stop_a | character varying(12) |
> stop_b | character varying(12) |
> Indexes:
> "link_stop_a" btree (stop_a)
> "link_stop_b" btree (stop_b)
> The table stop_link is a pre-generated table comprising of all stops
> within 300 metres of each other.
> What I want to be able to do is to find the routes needed to be taken
> from one location (Pointfromtext) to another using three connections.
> Three connections meaning three routes numbers. As you can see from
> the query the start bus stop and end bus stop must be located within
> 200 metres of the two corresponding points. And the first service must
> leave at the given time or any time ten minutes after that. Two
> changeovers of buses must be made mid-journey, and each change over
> must occur at least three minutes after arriving at the changeover
> stop.
> I hope this is all clear to you? If not please get back to me and I
> will try to explain further. Thanks so much for your help.
Right I see - ignoring the time constraints for a moment, this is a
routing problem. I suspect that the way forward with this would be to
look at the pgRouting project (http://pgrouting.postlbs.org/) using your
stops as vertices and services as edges.
I would suggest you have a look at the above site first, and then post
back with any more queries that you have. It's just I suspect that this
will be faster (and less complicated) if you can use this rather trying
to model the network functions in SQL.
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
