[postgis-users] Problem with slow GeomUnion (geom, geom)
Håvard Tveite
havard.tveite at umb.no
Fri Jun 1 07:16:40 PDT 2007
This is probably a map overlay, and not a traditional spatial join.
See:
<URL: http://en.wikipedia.org/wiki/Geographic_information_system#Map_overlay >
The PostGIS Intersection(geometry,geometry) is a relevant
operation.
Håvard
Mark Cave-Ayland wrote:
> On Fri, 2007-06-01 at 12:00 +0200, Matt Doughty wrote:
>> Hi Mark,
>> I'm trying to do a geometric union (I'm more used to doing these things
>> in ArcGIS where it'd be a union: A topological overlay of two or more
>> polygon spatial datasets that preserves the features that fall within
>> the spatial extent of either input dataset; that is, all features from
>> both datasets are retained and extracted into a new polygon dataset
>> (ESRI website))
>> In this case I'm not bothered about what happens to attributes, it's the
>> polygons that I want.
>> The input tables are as follows:
>> 1. Table1
>> name character varying(70),
>> the_geom geometry
>> 2. Table 2
>> the_geom geometry
>> Cheers,
>> Matt
> Okay, this is getting a little out of my comfort zone so someone else
> may need to help out here - is basically what you want to return all the
> polygons that overlap each other from your two tables?
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
