[postgis-users] Problems with MakePoint
Gustavo Ces
g.ces at pettra.es
Mon Jun 4 03:41:57 PDT 2007
Hi all,
i´m trying to makepoints from coordinate data ( x and y column) in one table( montouto2000). This is what i do..
SELECT AddGeometryColumn('public', 'montouto2000', 'the_geom', 23029, 'POINT', 2)
update montouto2000 set the_geom=MakePoint(x,y)
and Postgis says...
ERROR: new row for relation "montouto2000" violates check constraint "enforce_srid_the_geom"
Estado SQL:23514
I´ve got two questions:
1. What is the column dimension? i try to set it as 0 (poinst are no dimension geometries) but it says there´s a problem with the dim constraint, so i supose dimesion=number of coordinates? I don´t know, please, help.
2. What happens with SRID? why does PostGis Scream?
Thanks in advance,
Gus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070604/8ed8b686/attachment.html>
