[postgis-users] Cut a hole in a line layer (opposite of a cookie cutter)??
Matt Doughty
matt.doughty at geograma.com
Mon Jun 4 03:54:21 PDT 2007
I've got a new problem... how in PostGIS could I perform the opposite of
a cookie cutting operation? Better said, use a polygon layer to cut a
hole in a line layer thereby keeping the lines from outside the polygons
but not those inside. I've been trying with a cooking cutting script
(see below) by placing NOT before the operators but without much luck.
SELECT
cookie.gid,
INTERSECTION(cookie.the_geom, cutter.the_geom) AS the_geom
INTO
curvas_isla_not_02
FROM
roads AS cookie,
urban_areas AS cutter
WHERE
cookie.the_geom && cutter.the_geom
AND
INTERSECTS(cookie.the_geom, cutter.the_geom)
I've also tried to use the results from the cookie cutter script to
select those lines that don't coincide with those from the cookie (see
below), but also without any luck.
SELECT
roads.gid,
roads.the_geom
INTO
roads_not_urban
FROM
roads,
roads_urban
WHERE
roads.the_geom && roads_urban.the_geom
AND
NOT INTERSECTS(roads.the_geom, roads_urban.the_geom);
If anybody's got any tips on how to do this, or advice on where I'm
going wrong....!
Many thanks,
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070604/01c8eb66/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070604/01c8eb66/attachment.jpg>
