[postgis-users] Cut a hole in a line layer (opposite of a cookiecutter)??
Matt Doughty
matt.doughty at geograma.com
Mon Jun 4 09:15:06 PDT 2007
The 'Difference(geometry,geometry)' tool? I've had a look at that but
could quite understand how it works and what the syntax was, the PostGIS
manual was particularly unhelpful.
I'll have another look the how I can take the difference, but in the
meantime, if you've got any pointers...
... Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de
Martin Davis
Enviado el: lunes, 04 de junio de 2007 17:53
Para: PostGIS Users Discussion
Asunto: Re: [postgis-users] Cut a hole in a line layer (opposite of a
cookiecutter)??
You could form the union of the "mask" polygons and then use the
difference function to obtain the portion of each line which lies
outside them.
This assumes of course that your polygon layer isn't too big. If it is
very big, you may need to use the approach of taking the difference of
every line from the union of the polys which interact with that line.
This might be slow, however.
Matt Doughty wrote:
> Hi,
> I've got a new problem... how in PostGIS could I perform the opposite
of
> a cookie cutting operation? Better said, use a polygon layer to cut a
> hole in a line layer thereby keeping the lines from outside the
> polygons but not those inside. I've been trying with a cooking cutting
> script (see below) by placing NOT before the operators but without
> much luck.
> SELECT
> cookie.gid,
> INTERSECTION(cookie.the_geom, cutter.the_geom) AS the_geom
> INTO
> curvas_isla_not_02
> FROM
> roads AS cookie,
> urban_areas AS cutter
> WHERE
> cookie.the_geom && cutter.the_geom
> AND
> INTERSECTS(cookie.the_geom, cutter.the_geom)
> I've also tried to use the results from the cookie cutter script to
> select those lines that don't coincide with those from the cookie (see
> below), but also without any luck.
> SELECT
> roads.gid,
> roads.the_geom
> INTO
> roads_not_urban
> FROM
> roads,
> roads_urban
> WHERE
> roads.the_geom && roads_urban.the_geom
> AND
> NOT INTERSECTS(roads.the_geom, roads_urban.the_geom);
> If anybody's got any tips on how to do this, or advice on where I'm
> going wrong....!
> Many thanks,
> Matt
> Matt Doughty
> GEOGRAMA S.L.
> www.geograma.com
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
