[postgis-users] Slow select from big table
Matt Doughty
matt.doughty at geograma.com
Wed Jun 6 09:18:16 PDT 2007
I'll try it out.
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Obe, Regina
Enviado el: miércoles, 06 de junio de 2007 18:17
Para: PostGIS Users Discussion
Asunto: RE: [postgis-users] Slow select from big table
I know in prior versions of Postgresql, select count(*) was slow. I think it has improved, but may be still slower than doing a count of a specific field.
Have you tried doing something like
select count(gid) from sometable
to see if that is any faster where gid is a field in the table that is guaranteed not to be null or a primary key.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt Doughty
Sent: Wednesday, June 06, 2007 11:57 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Slow select from big table
Version 1.6.3.
Alter carrying out a full vacuum, the same query took ten seconds more. I'm going to try a vacuum analyse now, then the scripts I've been sent.
Matt
Matt Doughty
GEOGRAMA S.L.
www.geograma.com
De: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Gerry Creager
Enviado el: miércoles, 06 de junio de 2007 17:54
Asunto: Re: [postgis-users] Slow select from big table
What version of the database code are you running?
volunteer at spatiallink.org wrote:
> what if
> select count(*) from table where true;
> sincerely
> siva
> -------- Original Message --------
> From: "Matt Doughty" <matt.doughty at geograma.com>
> Date: Wed, June 06, 2007 11:30 am
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> I'm trying out a vacuum at the moment to see if it helps. Matt
> Matt Doughty GEOGRAMA S.L. Tel.: +34 945 13 13 72
> 652 77 14 15 Fax: +34 945 23 03 40 www.geograma.com
> [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Rob
> Tester
> Enviado el: miércoles, 06 de junio de 2007 17:23
> Para: 'PostGIS Users Discussion'
> Sounds more like a question for the general group. But, have you run a
> vacuum analyze on the table ?
> Matt Doughty
> Sent: Wednesday, June 06, 2007 8:19 AM
> To: postgis-users at postgis.refractions.net
> Cc: Sergio Jorrín Abellán
> Subject: [postgis-users] Slow select from big table
> Hi List, I've got a simple question, how can I speed up this query?
> SELECT COUNT (*) FROM table1 Currently it's taking a little more than
> five minutes to run on a table with 3.4 m rows. The table is gist
> indexed. Is it normal that Postgres takes so long? Cheers, Matt
> postgis-users mailing list
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
