[postgis-users] Merging two features
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 9 16:33:11 PDT 2007
Brent Wood wrote:
> --- Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> I think that should be geomunion, not union, in the SQL.
Right, good catch. Thanks.
> Brent Wood
>> Jeff Dege wrote:
>>> I have a shapefile that contains a few duplicated features.
>>> They have identical attribute data, different OGRFeature numbers, and
>>> different geometries.
>>> I've imported them into PostGIS, but having two different records for
>>> the same feature is causing some problems.
>>> The schema is simple:
>>>    CREATE TABLE "public"."counties" (gid serial PRIMARY KEY,
>>>    "state" varchar(2),
>>>    "name" varchar(18),
>>>    "wtr" int2,
>>>    "fips" int4);
>>>    SELECT
>>> AddGeometryColumn('public','counties','the_geom','4267','MULTIPOLYGON',2
>>> The duplicates are easy to find:
>>>    select state, name, count(*)
>>>    from counties
>>>    group by state, name
>>>    having count(*) > 1
>>> What I would like to do is to merge these duplicate records into a
>>> single record, containing a union of the separate records' geometries.
>>> But I'm not sure of exactly how to approach it.
>> Jeff,
>> Create a temp table
>> insert into temp (select state, name, wtr, fips, union(the_geom) from
>> countries group by states, name having count(*) > 1 );
>> check that it did what you expected, then delete the records by state,
>> name and insert the temp table records into the original table.
>> or you can alter you table to add a column which is used to track the
>> unioned records when they are added so you can delete the non-unioned
>> records that you don't want. You can alter the table to drop the column
>> when you are done.
>> -Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
