FW: [postgis-users] Insert transformed coordinates
Gary Townsend
garyt at spatialmapping.com
Mon Jun 11 08:39:22 PDT 2007
-----Original Message-----
From: Gary Townsend [mailto:garyt at spatialmapping.com]
Sent: June 11, 2007 8:37 AM
To: 'Charlton Purvis'
Subject: RE: [postgis-users] Insert transformed coordinates
Actually I found the problem, someone on the pgsql-novice list pointed out
my error I was missing a concatenation in my point string and on top of that
I had the parameter for projection as numeric rather than integer so when it
would try to run gemofromtext it would return that it couldn't find a
function with that signature. Here is the final function that worked.
CREATE OR REPLACE FUNCTION vts_insert_stop(text, text, numeric, numeric,
integer)
RETURNS void AS
DECLARE
stopnum ALIAS for $1;
stopdes ALIAS for $2;
stopeasting ALIAS for $3;
stopnorthing ALIAS for $4;
projection ALIAS for $5;
transCoord RECORD;
BEGIN
SELECT INTO transCoord X(SubSel.transformed_geom),
Y(SubSel.transformed_geom) FROM (
SELECT SetSRID(
Transform(
GeomFromText(
''POINT('' || stopeasting || '' '' || stopnorthing || '')'',
projection
), 4326
-1) AS transformed_geom) SubSel;
INSERT INTO
vts_route_stops(stop_number,stop_description,stop_latitude,stop_longitude)
VALUES(stopnum,stopdes,transCoord.Y,transCoord.X);
RETURN void;
END'
LANGUAGE 'plpgsql' VOLATILE;
From: Charlton Purvis [mailto:cplist at secondcreek.org]
Sent: June 8, 2007 2:43 PM
To: 'PostGIS Users Discussion'
Cc: garyt at spatialmapping.com
Gary,
That part of the select into looks suspicious to me. Have you tried
selecting into plain variables?
declare
my_x float;
my_y float;
select into my_x, my_y X(SubSel.transformed_geom),
SELECT SetSRID(
INSERT INTO
VALUES(stopnum,stopdes,my_y,my_x);
I think that will work. I might be off in the syntax above, but what looks
weird is the way you're selecting into components of a record set.
Charlton
