[postgis-users] closest points of two polygons
Robert Nuske
rnuske at gwdg.de
Thu Jun 14 04:54:46 PDT 2007
Hi Martin,
can you give me any pointers how to go about it?
thanks,
robert
Am Mittwoch, 13. Juni 2007 23:11 schrieben Sie:
> Yes, there is a JTS function which does this.
> The deterimination of which two points are closest in two geometries is
> computed as part of the distance operation. It just usually isn't
> exposed. Should be an easy addition to make to PostGIS, I would think.
> Robert Nuske wrote:
> > Hi All,
> > is there a way to get the closest points of two polygons?
> > Basically the points on the polygons, which are used for the distance
> > calculations.
> > I couldn't find anything among the postgis-functions (which might be
> > caused by my greenness) that would return the two closest points. But
> > isn't there a function in geos/JTS doing just that.
> > I hope somebody can suggest a nice and easy way to obtain the points on
> > the boundaries of two polygons with the shortest distance.
> > Any help is more than welcome.
> > cheers,
> > robert
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Robert Nuske
Institute for Forest Biometrics &
Applied Computer Science
Buesgenweg 4
37077 Goettingen
GERMANY
Phone: +49-551-39-2362
Fax : +49-551-39-3465
