[postgis-users] Problem with "Different SRIDs"
Rob Tester
robtester at gmail.com
Wed Jun 20 10:26:00 PDT 2007
You might want to do a transform instead of setSRID. If you do a set and the
coordinates arent in the correct coordinate system you will have more
problems than mismatched SRIDs, but now they could be masked.
Rob
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Patricio
Cifuentes Ithal
Sent: Wednesday, June 20, 2007 10:19 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Problem with "Different SRIDs"
Set the geometry
WHERE setSRID (geometry,xxxx) && setSRID(box2d('BOX3D(-0.5
-0.302040816326531,0.5 0.302040816326531)'::box3d),29101)
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Juliano
Zaban
Enviado el: miércoles, 20 de junio de 2007 10:41
Para: postgis-users at postgis.refractions.net
Asunto: [postgis-users] Problem with "Different SRIDs"
Hello all!
I'm trying to use PostGIS with SharpMap library to develop GIS applications.
However when the PostGIS extension for SharpMap try to run the following
query an error occurs:
SELECT AsBinary(geometry) AS Geom FROM bairros
WHERE geometry && setSRID(box2d('BOX3D(-0.5 -0.302040816326531,0.5
ERROR: Operation on two geometries with different SRIDs
SQL state: XX000
I believe the "bairros" layer is ok because I can edit it with OpenJUMP
without problem...
Anybody can help me with this?
Thanks a lot!
Este mensaje ha sido analizado por MailScanner
<http://www.mailscanner.info/>
en busca de virus y otros contenidos peligrosos,
y se considera que está limpio.
<http://www.siigsa.cl> www.siigsa.cl
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070620/d9a1963d/attachment.html>
