[postgis-users] postgis - polygon load failed
Peter Shrock thesl at yahoo.com
Wed Jun 20 13:20:50 PDT 2007
Dear all:
I have installed Postgresql 8.2.4 (windows 2000 platform).
I have loaded a few shapefiles from the ESRI sample data using shp2pgsql
successfully.
However, I have difficulties to load my working shapefiles. These shapefiles
have been generalized (vertex have been reduced).
The pgadmin log is:
2007-06-20 14:19:56 ERROR  : server sent data ("D" message) without prior row
description ("T" message)
could not receive data from server: No buffer space available
(0x00002747/10055)
The layer cannot loaded into Quantum GIS either - invalid layer.
The shapefiles can be operated properly in ArcGIS/ArcView.
Does any one know the reason? I assume that it had something to do with
geometry. Any way to solve this issue?
You help is much appreciated.
Peter.
____________________________________________________________________________________
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
