[postgis-users] Midpoint function?
Pradeep B V
pradeepbv at gmail.com
Thu Jun 21 07:34:37 PDT 2007
On 6/21/07, Rodrigo Martín LÓPEZ GREGORIO <
rodrigomartin at lopezgregorio.com.ar> wrote:
> As Nicolas says you should use:
> select line_interpolate_point(LineMerge(the_geom),0.5).
> you can try this and see if the point is the one you want:
It works fine.
and here is the proof.
select distance(startpoint(the_geom),
line_interpolate_point(LineMerge(the_geom),0.5)) as stdist,
distance(endpoint(the_geom), line_interpolate_point(LineMerge(the_geom),0.5))
as endist from testdataset limit 1;
stdist | enddist
0.000737003466840363 | 0.000737003466840363
Thanks Rodrigo/Nicolas.
- Pradeep B V
www.btis.in
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070621/63a9b7ee/attachment.html>
