[postgis-users] Re: [Plr-general] Tutorial on PLR and PostGIS, more on carriage returns
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jun 21 10:30:42 PDT 2007
Hmmmm, I am probably wrong on this but I thought 0x0 - 0x7f are standard
UTF8 characters with a constant meaning that is the same as ascii for
those bytes, and the all multi-byte characters had to have a the
highorder bit set to indicate is was part of a multibyte sequence.
I was not under the impresion that at you could have 0x0 - 0x7f as a
part of a multi-byte sequence. I am not an expert in this area and
probably just know enough to mislead you ;) but I think it is worthwhile
getting some additional inside into this. I for one would like to see a
multi-byte UTF8 sequence with \r embedded in it.
-Steve
Paul Ramsey wrote:
> Danger, will Robinson. All values are fair game in bytes 2,3,4 of the
> UTF encodings, so yes, it's possible you'll wreck multi-byte characters
> by doing a simple replacement on the byte array. Better to use an
> encoding-aware string replace function (not knowing C, I don't know what
> that would be, but there must be some in the PgSQL code base).
> P
> On 21-Jun-07, at 7:03 AM, Joe Conway wrote:
>> Obe, Regina wrote:
>>> Joe,
>>> Can you take a look at it again. It was messed up in my firefox
>>> too. I think originally I had it looking right in Firefox, but then
>>> IE it didn't look right so I changed it to look right in IE, but
>>> forgot to check back in firefox. Hopefully this time I have made all
>>> browser masters happy.
>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut02
>> The tutorial looks perfect now in Firefox on Fedora Core 7.
>> BTW, I have confirmed on the R-devel list that the R engine is
>> expecting \n for EOL, and \r will cause a syntax error, on all
>> platforms. I will probably fix this by simply replacing \r with \n in
>> PL/R functions. My only reservation is whether this might cause issues
>> for installations with multibyte characters. Does anyone know if it is
>> possible for multibyte characters to include a byte = 13 (\r), i.e. is
>> the simple replacement of \r safe in all locales?
>> Thanks,
>> Joe
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
