[postgis-users] WKT specification ?? Lon/Lat precision ?
Sébastien Geindre sebastien.geindre at meteo.fr
Fri Jun 22 06:10:55 PDT 2007
Mark Cave-Ayland a écrit :
> On Fri, 2007-06-22 at 14:56 +0200, Sébastien Geindre wrote:
>> my example is wrong, in fact i have 16 column but for the post i try to
>> keep 3 column....
>> but the pb comes from lat/lon precision...of format but from Polygon WKT
>> format...
>> sorry
> Okay, then let's try a simple test case:
> CREATE TABLE foo AS (id int, the_geom geometry);
> INSERT INTO foo (id, the_geom) VALUES (1,
> GeometryFromText('POLYGON((0.672702 49.9706, 3.90024 49.97063, 3.90024
> 47.6684, 0.672702 47.6684, 0.672702 49.9706 ))', -1 ));
> SELECT astext(the_geom) FROM foo;
> Does this work for you?
i found !!!
sorry for time lost..
it was  copy/paste between specification document (open office) with
wrong character inside the insert request !!! i am crazy !!
a question, if the column is specified with srid 4326 for instance, when
i insert data with -1, what happens ?
thanks for your time.
> Kind regards,
> Mark.
Sébastien Geindre
DPREVI/AERO/DEV
05 61 07 84 93
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070622/18a097e0/attachment.html>
