[postgis-users] Joined, queried or table views in Mapserver Mapfile.
Giuseppe Molinario
g.molinario at gmail.com
Wed Jun 27 01:43:56 PDT 2007
Hi everyone,
Wondering if this question is not better suited for a Mapserver forum, I'll
post it anyway in case someone has an easy solution...
My problem is this: I am usind the following layer in a Mapserver based
application. The DATA connection works, objects are visible on the map in
their correct place and symbology, however the query of the postgis table
works only if I name the columns of the LEFT table in the RESULT FIELDS. How
do i get the thing to query also my Columns from the joined table? Why on
earth would i have the same problem usind the DATA connected to a table
view?
Thanks,
Giuseppe
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070627/f009d607/attachment.html>
