[postgis-users] TIGER geocoder question
Marvin delphet at gmail.com
Thu Jun 28 10:42:36 PDT 2007
Thank you so much, Stephen.. I'll check it out.
On 6/28/07, Stephen Frost <sfrost at snowman.net> wrote:
> * Marvin (delphet at gmail.com) wrote:
> > Thanks, Stephen. Your explanation helps me a lot. So you think that it
> is
> > possible just to change "roads_local" in the script to "completechain"?
> Well, looking back I actually recreate road_local from completechain by
> doing some simple type conversions and whatnot:
> create table roads_local (
>   ogc_fid       INTEGER,
>   geom          GEOMETRY,
>   module        VARCHAR(8),
>   tlid          INTEGER,
>   side1         INTEGER,
>   source        CHAR(1),
>   fedirp        VARCHAR(2),
>   fename        VARCHAR(30),
>   fetype        VARCHAR(4),
>   fedirs        VARCHAR(2),
>   cfcc          VARCHAR(3),
>   fraddl        INTEGER,
>   toaddl        INTEGER,
>   fraddr        INTEGER,
>   toaddr        INTEGER,
>   friaddl       CHAR(1),
>   toiaddl       CHAR(1),
>   friaddr       CHAR(1),
>   toiaddr       CHAR(1),
>   zipl          INTEGER,
>   zipr          INTEGER,
>   aianhhfpl     INTEGER,
>   aianhhfpr     INTEGER,
>   aihhtlil      CHAR(1),
>   aihhtlir      CHAR(1),
>   census1       CHAR(1),
>   census2       CHAR(1),
>   statel        INTEGER,
>   stater        INTEGER,
>   countyl       INTEGER,
>   countyr       INTEGER,
>   cousubl       INTEGER,
>   cousubr       INTEGER,
>   submcdl       INTEGER,
>   submcdr       INTEGER,
>   placel        INTEGER,
>   placer        INTEGER,
>   tractl        INTEGER,
>   tractr        INTEGER,
>   blockl        INTEGER,
>   blockr        INTEGER
> insert into roads_local
> select
>   ogc_fid,
>   wkb_geometry,
>   trim(module),
>   tlid,
>   side1,
>   trim(source),
>   trim(fedirp),
>   trim(fename),
>   trim(fetype),
>   trim(fedirs),
>   trim(cfcc),
>   to_number(fraddl,'99999999999'),
>   to_number(toaddl,'99999999999'),
>   to_number(fraddr,'99999999999'),
>   to_number(toaddr,'99999999999'),
>   trim(friaddl),
>   trim(toiaddl),
>   trim(friaddr),
>   trim(toiaddr),
>   zipl,
>   zipr,
>   aianhhfpl,
>   aianhhfpr,
>   trim(aihhtlil),
>   trim(aihhtlir),
>   trim(census1),
>   trim(census2),
>   statel,
>   stater,
>   countyl,
>   countyr,
>   cousubl,
>   cousubr,
>   submcdl,
>   submcdr,
>   placel,
>   placer,
>   tractl,
>   tractr,
>   blockl,
>   blockr
> from completechain;
> CREATE INDEX roads_local_tlid_idx ON roads_local (tlid);
> CREATE INDEX roads_local_geom_idx ON roads_local USING GIST (geom
> public.gist_geometry_ops);
> CREATE INDEX roads_local_cfcc_idx ON roads_local (cfcc);
> > One more question, there is another table missing
> ("tiger_geocode_join").
> Oh, yea, *that* thing.  It's a pointless table, honestly.  The idea
> behind it was to link from tiger_geocode_roads to roads_local, but if
> you just keep the tlid (as I did) from completechain in roads_local and
> then in tiger_geocode_roads you don't need that side-table.  That does
> require changing up the actual pl/pgsql code some though.  Basically go
> through all the queries, remove the join against '_join' and change the
> references to tlid to us the field from tiger_geocode_roads directly.
> The sequence in tiger_geocode_roads ends up not being used for anything.
> > One message says that "tiger_geocode_join" links "roads_local" and
> > "tiger_geocode_roads" but I can't seem to figure out what that means. Is
> > there a piece of script to create "tiger_geocode_join"?
> There could be, but it'd be ugly and silly. :)
> > As for the missing fields in "completechain", I meant "zip" and so on
> since
> > TIGER keeps both left and right zip and I had no idea what zip
> > "tiger_geocode_roads" uses. Now I can tell from your script.
> > Thank you very much.
> Sure.
>         Stephen
> > >* Shuo Liu (delphet at gmail.com) wrote:
> > >> I'm working on a GIS project and trying to use TIGER Geocoder from
> the
> > >> refractions website on TIGER data. The two sql files in the Geocoder
> > >> generated some errors when being loaded, complaining that some tables
> > >> ("gazetteer_places", "tiger_geocode_roads", "place_lookup",
> > >"roads_local",
> > >> and "countysub_lookup") are missing. Some messages from the mailing
> list
> > >say
> > >> that gazetteer tables should be loaded from the Census Bureau
> gazetteer
> > >> files. But that doesn't help find "tiger_geocode_roads" and
> > >"roads_local"
> > >> which don't exist in the loaded TIGER database. I used ogr2ogr to
> load
> > >the
> > >roads_local is essentially completechain.  tiger_geocode_roads is built
> > >off of that by mashing the two sides together into one file and
> removing
> > >the address from/to columns.  Takes a while to process but the SQL
> isn't
> > >terribly complex:
> > >DROP SEQUENCE IF EXISTS tiger_geocode_roads_seq;
> > >CREATE SEQUENCE tiger_geocode_roads_seq;
> > >DROP TABLE IF EXISTS tiger_geocode_roads;
> > >CREATE TABLE tiger_geocode_roads (
> > >    id      INTEGER,
> > >    tlid    INTEGER,
> > >    fedirp  VARCHAR(2),
> > >    fename  VARCHAR(30),
> > >    fetype  VARCHAR(4),
> > >    fedirs  VARCHAR(2),
> > >    zip     INTEGER,
> > >    state   VARCHAR(2),
> > >    county  VARCHAR(90),
> > >    cousub  VARCHAR(90),
> > >    place   VARCHAR(90)
> > >INSERT INTO tiger_geocode_roads
> > >  SELECT
> > >    nextval('tiger_geocode_roads_seq'),
> > >    tlid,
> > >    fedirp,
> > >    fename,
> > >    fetype,
> > >    fedirs,
> > >    zip,
> > >    state,
> > >    county,
> > >    cousub,
> > >    place
> > >  FROM
> > >   (SELECT
> > >      tlid,
> > >      fedirp,
> > >      fename,
> > >      fetype,
> > >      fedirs,
> > >      zipl as zip,
> > >      sl.abbrev as state,
> > >      co.name as county,
> > >      cs.name as cousub,
> > >      pl.name as place
> > >    FROM
> > >      roads_local rl
> > >      JOIN state_lookup sl on (rl.statel = sl.st_code)
> > >      LEFT JOIN county_lookup co on (rl.statel = co.st_code AND
> rl.countyl=
> > >co.co_code)
> > >      LEFT JOIN countysub_lookup cs on (rl.statel = cs.st_code AND
> > >rl.countyl = cs.co_code AND rl.cousubl = cs.cs_code)
> > >      LEFT JOIN place_lookup pl on (rl.statel = pl.st_code AND
> rl.placel =
> > >pl.pl_code)
> > >    WHERE fename IS NOT NULL
> > >    UNION
> > >    SELECT
> > >      tlid,
> > >      fedirp,
> > >      fename,
> > >      fetype,
> > >      fedirs,
> > >      zipr as zip,
> > >      sl.abbrev as state,
> > >      co.name as county,
> > >      cs.name as cousub,
> > >      pl.name as place
> > >    FROM
> > >      roads_local rl
> > >      JOIN state_lookup sl on (rl.stater = sl.st_code)
> > >      LEFT JOIN county_lookup co on (rl.stater = co.st_code AND
> rl.countyr=
> > >co.co_code)
> > >      LEFT JOIN countysub_lookup cs on (rl.stater = cs.st_code AND
> > >rl.countyr = cs.co_code AND rl.cousubr = cs.cs_code)
> > >      LEFT JOIN place_lookup pl on (rl.stater = pl.st_code AND
> rl.placer =
> > >pl.pl_code)
> > >    ) AS sub;
> > >CREATE INDEX tiger_geocode_roads_zip_soundex_idx          ON
> > >tiger_geocode_roads (soundex(fename), zip, state);
> > >CREATE INDEX tiger_geocode_roads_place_soundex_idx        ON
> > >tiger_geocode_roads (soundex(fename), place, state);
> > >CREATE INDEX tiger_geocode_roads_cousub_soundex_idx       ON
> > >tiger_geocode_roads (soundex(fename), cousub, state);
> > >CREATE INDEX tiger_geocode_roads_place_more_soundex_idx   ON
> > >tiger_geocode_roads (soundex(fename), soundex(place), state);
> > >CREATE INDEX tiger_geocode_roads_cousub_more_soundex_idx  ON
> > >tiger_geocode_roads (soundex(fename), soundex(cousub), state);
> > >CREATE INDEX tiger_geocode_roads_state_soundex_idx        ON
> > >tiger_geocode_roads (soundex(fename), state);
> > >> TIGER data (
> > >http://docs.codehaus.org/display/GEOSDOC/Loading+TIGER+basedata)
> > >> and it seems that some fields required by the Geocoder are in
> > >> "completechain" but not all. Can anybody who have experience share
> some
> > >hint
> > >> on this problem? Thank you very much.
> > >I'm curious what fields you think aren't available...?  Perhaps the
> > >folding from above will solve that for you...
> > >        Enjoy,
> > >                Stephen
> > >-----BEGIN PGP SIGNATURE-----
> > >Version: GnuPG v1.4.6 (GNU/Linux)
> > >iD8DBQFGg+UerzgMPqB3kigRAlihAJ4k/8Sf0ijbBnwkIvpwHQqv02IgjwCfXRiz
> > >0rNEYkBA3OCWr2le08i74ys=
> > >=eDK5
> > >-----END PGP SIGNATURE-----
> > >_______________________________________________
> > >postgis-users mailing list
> > >postgis-users at postgis.refractions.net
> > >http://postgis.refractions.net/mailman/listinfo/postgis-users
> iD8DBQFGg+vrrzgMPqB3kigRAvgDAJ9CjEYQNhlQHOTjBHUBqWO9IXfyzACfQ0jL
> fM058UoPBAQfpbX07Uz90TU=
> =mfHr
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070628/ce6461e1/attachment.html>
