[postgis-users] Problem with overlay
Jonathan Aguero jua130 at psu.edu
Sat Jun 30 11:05:27 PDT 2007
Listers
I got a multilinestringM shape that I loaded into postgis without problem
(LRS). Then I used the linear referencing functions to create the segments
and curves tables from the tables (BTW, these linear referencing functions
rock!!!!). Now, my problem is that when I tried to join the information on
curves into the segments table using the overlay function, it failed to
detect several curves. Note that both geometries (segments and curves) are
generated from the same base lines (LRS), therefore all curves should
overlay one or more segments. I am guessing I encountered a precision
problem on GEOS but I wonder whether my guess is correct and if there is any
solution (maybe snaptogrid).
Thanks in Advance for your help
PS:
OS: Windows XP
PGSQL: PostgreSQL 8.2.3 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
3.4.2 (mingw-special)
Postgis: 1.2
GEOS: 3.0.0rc4-CAPI-1.3.3
Jonathan Aguero Valverde
Research Assistant and Ph.D. Candidate
Pennsylvania State University
The Pennsylvania Transportation Institute
201 Transportation Research Building
University Park, PA 16802
www.personal.psu.edu/jua130
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070630/16c32ddf/attachment.html>
