[postgis-users] Spherical expand
Rob Young
bobbotron at gmail.com
Fri Mar 2 00:54:39 PST 2007
Hey guys,
A while ago I mentioned that I had written a postgres function that
acted as a expand function that worked with lat/long data. I thought
I'd pass it on to the list, in case other people might find it useful.
Included are two functions: expand_sphere and distance_from.
distance_from is a helper function for expand_sphere. expand_sphere
creates a polygon around the lat and long coordinates passed to it,
the size of which is determined by the radius value you give it (in
metres.) It uses a spherical earth approximation for the underlying
math. Currently it doesn't handle wraparound. So, it could in theory
create a box that bounds outside of the normal lat/long bounds. (I'm
on vacation, I'll get around to writing the boundery cases when I get
back home. Also, more commenting then...) :)
Cheers!
Rob Young
Ps: hopefully the attached code is preserved in some useable form.. :)
---- See => http://williams.best.vwh.net/avform.htm#LL
---- lat=asin(sin(lat1)*cos(d)+cos(lat1)*sin(d)*cos(tc))
---- IF (cos(lat)=0)
---- lon=lon1 // endpoint a pole
---- ELSE
---- lon=mod(lon1-asin(sin(tc)*sin(d)/cos(lat))+pi,2*pi)-pi
---- ENDIF
CREATE OR REPLACE FUNCTION distance_from( IN lat real, -- Latitude in degrees
IN long real, -- Longitude in degrees
IN course real, -- course in degrees
IN dist real ) -- distance in metres
RETURNS geometry AS $$
DECLARE
radius_km real; -- CONSTANT radius of the earth
latRad real;
longRad real;
courseRad real;
distRad real;
newLatRad real;
newLongRad real;
newLat real;
newLong real;
BEGIN
radius_km = 6378.137; -- radius of the earth (ROUGHLY, CHECK!)
latRad := ( pi() / 180.0 ) * lat;
longRad := ( pi() / 180.0 ) * long;
courseRad := ( pi() / 180.0 ) * course;
distRad := ( dist / 1000.0 ) / radius_km;
newLatRad := asin(sin(latRad)*cos(distRad)+cos(latRad)*sin(distRad)*cos(courseRad));
newLongRad := 0.0;
IF cos( newLatRad ) = 0 THEN
newLongRad = longRad;
ELSE
--newLongRad =
mod(longRad-asin(sin(courseRad)*sin(distRad)/cos(lat))+pi(), 2 * pi())
- pi();
newLongRad = cast(longRad-asin(sin(courseRad)*sin(distRad)/cos(latRad))+pi()
as numeric ) % cast( 2 * pi() as numeric ) - pi();
END IF;
newLat := ( 180.0 / pi() ) * newLatRad;
newLong := ( 180.0 / pi() ) * newLongRad;
RETURN SetSRID( MakePoint( newLong, newLat ), 4326 );
END;
$$ LANGUAGE plpgsql IMMUTABLE;
CREATE OR REPLACE FUNCTION expand_sphere( IN lat real, -- Latitude in degrees
DECLARE
a geometry;
b geometry;
c geometry;
d geometry;
llPoint geometry;
urPoint geometry;
sphereBox box2D;
BEGIN
a := distance_from( lat, long, 0.0, dist );
b := distance_from( lat, long, 90.0, dist );
c := distance_from( lat, long, 180.0, dist );
d := distance_from( lat, long, 270.0, dist );
llPoint := MakePoint( X( d ), Y( c ) );
urPoint := MakePoint( X( b ), Y( a ) );
sphereBox := MakeBox2D( llPoint, urPoint );
RETURN SetSRID( sphereBox, 4326 );
END;
---- ELSE
---- ENDIF
DECLARE
latRad real;
longRad real;
courseRad real;
distRad real;
newLatRad real;
newLongRad real;
newLat real;
newLong real;
BEGIN
newLongRad := 0.0;
---- ELSE
---- ENDIF
ELSE
--newLongRad = mod(longRad-asin(sin(courseRad)*sin(distRad)/cos(lat))+pi(), 2 * pi()) - pi();
newLongRad = cast(longRad-asin(sin(courseRad)*sin(distRad)/cos(latRad))+pi() as numeric ) % cast( 2 * pi() as numeric ) - pi();
END IF;
END;
DECLARE
a geometry;
b geometry;
c geometry;
d geometry;
llPoint geometry;
urPoint geometry;
sphereBox box2D;
BEGIN
END;
