[postgis-users] GeomUnion() strange results
Paul Ramsey
pramsey at refractions.net
Fri Mar 2 09:39:38 PST 2007
Any chance you can update your GEOS to rc4 Horst? Shouldn't break
anything, only make things better...
P
Düster Horst wrote:
> I try to create the exterior boundary of all polygons of the attached
> postgis polygon table with:
> select geomunion(wkb_geometry) from test;
> As the result I don't get the expected result. Only parts of the input
> polygons are dissolved. The culprit seems to be the polygon with gid=1.
> This polygon is very complex with many vertex points. All geometries are
> valid, checked by isValid(wkb_geometry). Please use the attached
> geometry table to reproduce this behaviour.
> My System:
> PostgreSQL 8.1.6 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.4
> 20050721 (Red Hat 3.4.4-2)
> POSTGIS="1.1.5" GEOS="3.0.0rc1-CAPI-1.2.0" PROJ="Rel. 4.4.8, 3 May 2004"
> USE_STATS
> I would appreciate any hint.
> Best regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
