[postgis-users] Question Upgrading to PostgreSQL8.2 PG1.2.1
Paul Ramsey
pramsey at refractions.net
Wed Mar 7 14:27:25 PST 2007
PostGIS doesn't require a hard upgrade from 1.1 -> 1.2.
PostgreSQL on the other hand, *does* require a hard upgrade from 8.1 to 8.2.
P
Obe, Regina wrote:
> I'm trying to think what version I had before 1.2.1. I think it was
> 1.1.1 or perhaps even lower and I just did a soft upgrade. I don't
> recall running into any problems doing a soft upgrade.
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Randy George
> *Sent:* Wednesday, March 07, 2007 4:31 PM
> *To:* 'PostGIS Users Discussion'
> *Subject:* [postgis-users] Question Upgrading to PostgreSQL8.2 PG1.2.1
> Hi,
> I have a question on upgrading to newer version of
> PostgreSQL/PostGIS on Windows
> Using:
> Windows 2003
> Old:
> postgis_full_version
> "POSTGIS=""1.1.1"" GEOS=""2.2.1-CAPI-1.0.1"" PROJ=""Rel. 4.4.9, 29 Oct
> 2004"" USE_STATS DBPROC=""0.3.0"" RELPROC=""1.1.1"" (needs proc upgrade)"
> New:
> PostgreSQL 8.2.3 - postgresql-8.2.3-1
> PostGIS 1.2.1 - postgis-pg82-setup-1.2.1-1.exe
> "POSTGIS=""1.2.1"" GEOS=""2.2.3-CAPI-1.1.1"" PROJ=""Rel. 4.5.0, 22 Oct
> 2006"" USE_STATS"
> I assume that I need to do a hard upgrade. I am using the pgAdmin III
> backup/restore for transferring dbs to the upgraded version.
> In order to make this work I manually create each of the DBs in the new
> version using the default template_postgis and then do a Restore from
> the previously exported 8.1 ..backup. This is a bit time consuming with
> several large DBs like TIGER2005, NHD, DCW etc, but appears to work.
> Looking over the restore log there are a number of warning/errors:
> WARNING: errors ignored on restore: 364
> Process returned exit code 1.
> Most of the errors seem to be with the PostGIS functions which already
> exist from create with template_postgis. For example:
> pg_restore: creating FUNCTION geometry_analyze(internal)
> pg_restore: [archiver (db)] Error from TOC entry 30; 1255 16421 FUNCTION
> geometry_analyze(internal) postgres
> pg_restore: [archiver (db)] could not execute query: ERROR: function
> "geometry_analyze" already exists with same argument types
> Command was: CREATE FUNCTION geometry_analyze(internal) RETURNS boolean
> AS '$libdir/liblwgeom.dll', 'LWGEOM_analyze'
> LANGUAGE c S...
> In spite of the “exit code 1“ the tables seem to be restored correctly
> allowing my usual queries.
> Note: I do need to add my custom spatial_ref_sys entries with sql
> insert, since:
> pg_restore: [archiver (db)] could not execute query: ERROR: relation
> "spatial_ref_sys" already exists
> However, I am wondering if some issue will surface down the road due to
> the ignored warning/errors?
> If there is a more efficient approach for transferring large DBs that
> I’m missing, I’d like to know about it.
> Also thanks for adding the asKML() function! These export functions
> asGML, asSVG, asKML are really a help!
> Thanks
> randy
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
