[postgis-users] Insert geometry in a table
Kai Behncke
kbehncke at igf.uni-osnabrueck.de
Fri Mar 9 05:39:57 PST 2007
On Fri, 9 Mar 2007 14:11:05 +0100, Kai Behncke wrote
> Hello list,
> I wonder how to integrate a geometry in a table with INSERT.
> If I write: INSERT INTO "city" ("gid","name",the_geom) VALUES
> ('189','osnabrueck','SRID=31467; MULTIPOLYGON(((3434250 5793220,3435960
> 5793220,3435960 5794870,3434250 5794870, 3434250 5793220)))');
> this works fine.
> But I want to get the geom out of a table to produce a new geomtry
> with a buffer.
> If I write:
> INSERT INTO "city" (name,the_geom) SELECT
> 'test',astext(buffer(p.the_geom,500)) FROM poi p
> WHERE p.poinameid='Marienhospital'; this wokrs fine as well, but
> only if there are no constraints in the table "city".
> How can I make it that I insert the buffer(p.the_geom,500) as the geometrytype
> POLYGON and with SRID=31467??
> Has anybody an idea?
> Thank you in advance.
> Kai
Allright, got an idea by myself.
It works with:
'hallo',setSRID((buffer(p.the_geom,500)),31467) FROM poi p
To produce a multipolygon:
'hallo',MULTI(setSRID((buffer(p.the_geom,500)),31467)) FROM poi p
Dipl.-Geogr. Dipl.-Umweltwiss. Kai Behncke
Institut für Geoinformatik und Fernerkundung (IGF)
Universität Osnabrück
Kolpingstr. 7
49074 Osnabrück
Raum: 01/308
Tel.: +49 541 969-4450
E-Mail: mailto:kbehncke at igf.uni-osnabrueck.de
Web: http://www.igf.uni-osnabrueck.de/mitarbeiter/behncke/index.html
