[postgis-users] Re: GiST index seems to be ignored?
Reid Priedhorsky reid at umn.edu
Fri Mar 9 09:40:27 PST 2007
Josh Livni wrote:
> I am basically trying to find points within a buffered polygon.  I've
> created a GiST index on my polygons:
> CREATE INDEX kc_block_groups_qm_buffer_the_geom_gist
>  ON kc_block_groups
>  USING gist
>  (buffer(the_geom, 1320::double precision));
> SELECT
>    count(j."lfc_code") as count,
>    sum(J."gross_sqft") as Sum_Gross_Sqft,
>    sum(j."units") as Sum_Units,
>    j."lfc_code"
>    FROM kc_block_groups b, parcels_06 p inner join lfc_comm j on
> p.pin_key = j.pin_key
>    WHERE buffer(b.the_geom,90) && centroid(p.the_geom)
>    and within(centroid(p.the_geom), buffer(b.the_geom,1320))
>    and b.fips = 530330001001
>    GROUP BY j."lfc_code"
within() won't take advantage of the index, and with the operator that
does (&&), your buffer() call uses a different buffer distance. What
happens if you create the index on buffer(the_geom, 90)?
My other guess is that you use a typecast in the index creation but not
the query.
Good luck,
Reid
