[postgis-users] Re: GiST index seems to be ignored?
Obe, Regina
robe.dnd at cityofboston.gov
Fri Mar 9 11:11:17 PST 2007
Just noticed something else in your prior email which I think Reid may have alluded to.
Is your fips stored as an integer or as a varchar or text? It looked from your query plan that it is probably being stored as text which may explain why your fips index is not being used if it really is not being used because it may be casting it to an int to match your where clause thus not finding a suitable index.
What if you tried the original I gave you with quoting the fips code instead of treating it as number. like below. Note I also changed my original p.the_geom to centroid(p.the_geom) because I am assuming you have an index on centroid(p.the_geom) and not necessarily on p.the_geom.
SELECT
count(j."lfc_code") as count,
sum(J."gross_sqft") as Sum_Gross_Sqft,
sum(j."units") as Sum_Units,
j."lfc_code"
FROM kc_block_groups b, parcels_06 p inner join lfc_comm j on
p.pin_key = j.pin_key
WHERE expand(b.the_geom,1320) && centroid(p.the_geom)
and within(centroid(p.the_geom), buffer(b.the_geom,1320))
and b.fips = '530330001001'
GROUP BY j."lfc_code"
From: postgis-users-bounces at postgis.refractions.net on behalf of Obe, Regina
Sent: Fri 3/9/2007 1:44 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Re: GiST index seems to be ignored?
Interesting. So was it not using the fips index at all? Just curious can you try this query
SELECT p.*
FROM (SELECT buffer(kc_block_groups.the_geom, 1320) as thebuffer FROM kc_block_groups AND kc_block_groups.fips = 530330001001) b INNER JOIN parcels_06 p ON b.thebuffer && centroid(p.the_geom)
WHERE within(centroid(p.the_geom), b.thebuffer)
From: postgis-users-bounces at postgis.refractions.net on behalf of Josh Livni
Sent: Fri 3/9/2007 1:29 PM
Subject: Re: [postgis-users] Re: GiST index seems to be ignored?
Regina,
Thanks a lot for your detailed response (and to Reid too).
First, the 90 was a typo in my message, sorry -- the query was always
using just 1320 with it's slowness.
Also, I did have both a btree index on fips, and a GiST index on
centroid(parcels_06.the_geom)
I tried your query, and it too, took a couple minutes.
Moving on to some good news for me (and my not having to use my hack
workaround of temp tables with pre-calculated buffers):
Turns out, Mark Cave-Ayland was exceedingly helpful on IRC and managed
to solve this little issue, where it looks like forcing the planner's
hand was the key.
He narrowed it down, so we noticed that:
SELECT p.*
WHERE buffer(b.the_geom,1320) && centroid(p.the_geom)
and b.fips = 530330001001;
took > 110,000 ms to run.
whereas:
SELECT *
FROM parcels_06 AS p
WHERE
(SELECT buffer(the_geom, 1320) AS the_geomx
FROM kc_block_groups WHERE fips = 530330001001)
AND within(centroid(p.the_geom),
FROM kc_block_groups WHERE fips = 530330001001) );
took ~300ms to run.
Nice!
I put this back in my orig query, and it took about 1500ms:
SELECT
j."lfc_code"
WHERE
AS the_geomx
WHERE fips = 530330001001) && centroid(p.the_geom)
and within(centroid(p.the_geom), (SELECT buffer(the_geom, 1320)
AS the_geomx
GROUP BY j."lfc_code" ;
However, this compared to a ~350ms return time for the query on my temp
table of pre-buffered polygons:
SELECT
j."lfc_code"
FROM kc_bg_qm_buffer b, parcels_06 p inner join lfc_comm j on
WHERE b.the_geom && centroid(p.the_geom)
and within(centroid(p.the_geom), b.the_geom)
As I think Mark noted, since my queries are pretty much spatial, further
subselects to ensure the spatial stuff is done first might help. This
is my next step, but meanwhile here is a really significant improvement
- I hope the notes above might aid someone in a similar situation.
Thanks Mark!
Cheers,
-Josh
Obe, Regina wrote:
> Do you have a gist index on your p.the_geom.
> I think expand is much more efficient than buffer for your && and I
> think your centroid && instead of just using p.the_geom is totally
> wasteful. So I would change to do the falling
> 1) Add a btree index on fips on your block groups - a attribute index
> is almost always more selective than a spatial index.
> 2) I think you can drop that buffer index you have going, but if you
> do need to keep it change it to expand(b.the_geom, 90) - for this
> particular query, it probably won't be used anyway if you have an
> index on fips.
> 2) Make sure you have an index on p.the_geom
> 3) Change your query to
> SELECT
> j."lfc_code"
> WHERE expand(b.the_geom,90) && p.the_geom
> *From:* postgis-users-bounces at postgis.refractions.net on behalf of
> Reid Priedhorsky
> *Sent:* Fri 3/9/2007 12:40 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] Re: GiST index seems to be ignored?
> Josh Livni wrote:
> > I am basically trying to find points within a buffered polygon. I've
> > created a GiST index on my polygons:
> > CREATE INDEX kc_block_groups_qm_buffer_the_geom_gist
> > ON kc_block_groups
> > USING gist
> > (buffer(the_geom, 1320::double precision));
> > SELECT
> > j."lfc_code"
> > WHERE buffer(b.the_geom,90) && centroid(p.the_geom)
> within() won't take advantage of the index, and with the operator that
> does (&&), your buffer() call uses a different buffer distance. What
> happens if you create the index on buffer(the_geom, 90)?
> My other guess is that you use a typecast in the index creation but not
> the query.
> Good luck,
> Reid
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070309/13661d65/attachment.html>
