[postgis-users] Proposed new functions
Bruce Rindahl
rindahl at lrcwe.com
Tue Mar 13 11:31:25 PDT 2007
I already found a bug in the ellipse functions I proposed. The ellipse came
out twice as big as it should be. The correct functions are:
-- Function: Ellipse(double precision, double precision, double precision,
double precision, double precision, integer)
-- DROP FUNCTION Ellipse(double precision, double precision, double
precision, double precision, double precision, integer);
CREATE OR REPLACE FUNCTION Ellipse(double precision, double precision,
double precision, double precision, double precision, integer)
RETURNS geometry AS
'SELECT translate( rotate( scale( buffer(makepoint(0,0), 0.5, $6), $3, $4),
$5), $1, $2)'
LANGUAGE 'sql' IMMUTABLE STRICT;
ALTER FUNCTION Ellipse(double precision, double precision, double precision,
double precision, double precision, integer) OWNER TO postgres;
double precision, double precision)
precision, double precision, double precision);
double precision, double precision, double precision)
RETURNS geometry AS
'SELECT translate( rotate( scale( buffer(makepoint(0,0), 0.5), $3, $4), $5),
$1, $2)'
double precision, double precision) OWNER TO postgres;
The buffer radius was changed from 1 to 0.5
Thanks
Bruce Rindahl
