[postgis-users] Geometry Uses
Leticia lgomez at itba.edu.ar
Thu Mar 15 15:42:32 PDT 2007
Hi, I need to build a new index. It is similar to R-tree but their entries
nodes contains not only the MBRs but some numeric information.
I am using a "CREATE TYPE" in order to create the data type for the table.
The SQL sentences look like
CREATE TYPE New_Type
   internallength = -1,
   input = New_Type_IN,
   output = New_Type_OUT,
   storage= plain
CREATE TABLE proof (col   New_type);
CREATE INDEX anIndex ON proof USING GiST(  col   New_Type_Ops);
As I am creating an opaque data type, I need to create an equivalent one in
C language. I need something like this:
/* C language */
typedef struct My_New_Type
    unsigned int               size;
/* required to be a Postgres varlena type */
    float                          number;
    PG_LWGEOM           geometry;
} My_New_Type;
As I need to store a "geometry" inside the opaque data type, I use "varlena
type" convention for my declaration. The variable length (size) is because
the geometry that I have to store. I only have to store one geometry inside
my structure.
Must I use PG_LWGEOM?  Must I use LWGEOM?
Is it OK to declare my struct as VARIABLE because I encapsulate a GEOMETRY?
Could you help me?
Thanks in advance,
Leticia
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070315/4e81eea5/attachment.html>
