[postgis-users] CHAR data type
TECHER David
davidtecher at yahoo.fr
Wed Mar 21 07:13:00 PDT 2007
You're not in postgresql mailing-list here
it should be better to ask on irc
server: irc.freenode.net
chan #postgresql
Leticia a écrit :
> I am using PostgreSQL 8.2.3. with the default page size of 8K
> I created the following table:
> CREATE TABLE mystate( ID integer, name char(8000) );
> I inserted three tuples:
> INSERT INTO mystate VALUES (3, 'a3');
> INSERT INTO mystate VALUES (5, 'a5');
> INSERT INTO mystate VALUES (6, 'a6');
> And then I ran the following query:
> vacuum analyze mystate;
> select relpages, reltuples from pg_class where relname='mystate';
> but the result was:
> 1 3
> If I use “char(8000)” instead of “varchar(8000)” why there is no
> padding and these three tuples are inside the same page?
> Thanks in advance,
> Leticia
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
