[postgis-users] Dilemma: is gid really useful in a geoDB?
Paolo Corti
pcorti at gmail.com
Fri Mar 23 06:10:13 PDT 2007
exactly, adding the gid column is a convenience
in some case is mandatory
zigGis, the OS PostGIS connector for ArcGis, is for example waiting to
always have the gid field defined, otherwise it won't work.
Some other software can work even without it (QGis, but still needs a
primary key), but in the case of Esri GDB model there is a mandatory OID
integer field that will be translated from the gid field of a PostGIS layer,
and there is no way to avoid to add the gid field in PostGIS tables.
At this time zigGIs is assuming that the OID field is named gid, but maybe
we can reconsider the thing, and make it this name configurable in
configuration file....
Paolo Corti
Paul Ramsey wrote:
> Correct, almost all client applications require a primary key. Many
> require that the primary key be a single column. shp2pgsql creates a
> 'gid' automatically, but you could always drop it if you wanted some
> other primary key.
> Stephen Woodbridge wrote:
>> Antonello wrote:
>>> Hi list,
>>> I have a dilemma: is gid really useful in a geoDB?
>>> I am building a geodb for several harbor. When I create a layer(table
>>> with geometry) in postgis, I need a gid like a primary key, or I can
>>> use a different one? Can I use several field of from the table like a
>>> primary key?
>>> I am not new in the gis, but why in almost all geoDB I saw there is a
>>> gid?! Is it really necessary? Do it come from shapefile standards?
>>> For example QuantumGIS doesn't work if the layer has only one primary
>>> key, there are other application that don't work like qGis?
>> Hello Antonello,
>> There is basically a requirement to have some kind of unique way of
>> accessing any given record. This is so programs can update the record or
>> fetch the records later based on a unique id. Also some systems might
>> expect that the uid be an integer. So adding the gid column is a
>> convenience.
>> If you know your usage patterns and you know the requirements for the
>> software you are using with the database, then you can probably safely
>> remove or change it to something else. I don't think gid needs to be the
>> primary key if you have something else, you could just make the gid a
>> unique column.
>> -Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> http://www.refractions.net
> pramsey at refractions.net
> Phone: 250-383-3022
> Cell: 250-885-0632
View this message in context: http://www.nabble.com/Dilemma%3A-is-gid-really-useful-in-a-geoDB--tf3267570.html#a9634416
Sent from the PostGIS - User mailing list archive at Nabble.com.
