[Geoserver-devel] [postgis-users] Re: Postgis estimated_extent completely off the mark?
strk at refractions.net
Tue Mar 27 01:32:57 PDT 2007
Andrea, if your problem is with those isolated geoms far away, the
root is skipping "hard deviants" from analisys at estimation time.
See lwgeom_estimate.c and try tweaking these:
* Define this if you want to use standard deviation based
* histogram extent computation. If you do, you can also
* tweak the deviation factor used in computation with
* SDFACTOR.
#define USE_STANDARD_DEVIATION 1
#define SDFACTOR 3.25
--strk;
On Thu, Mar 22, 2007 at 03:23:22PM +0100, Andrea Aime wrote:
> Mark Cave-Ayland ha scritto:
> >Yes, it's due to the way in which the sampling works. Note that you can
> >increase the number of sampled rows using ALTER TABLE x ALTER COLUMN y
> >SET STATISTICS z and then re-ANALYZING (the default value is 10, so
> >perhaps a value of 100 would provide better results). I'm not sure where
> >the figure of 5% from proper bounds comes from though - I would have
> >imagined it depends on the sample size relative to the population size,
> >but then I haven't studied statistics properly for several years now :(
> Nice tip. I tried it out:
> alter table major_roads alter column gen_full set statistics 1000;
> vacuum analyze major_roads;
> tiger2005fe=# select estimated_extent('major_roads','gen_full');
> estimated_extent
> BOX(-136.358154296875 17.6865196228027,-64.5742340087891 59.6282997131348)
> Sigh... the result is the same as before...
> I tried setting a value bigger than 1000, the result is:
> tiger2005fe=# alter table major_roads alter column gen_full set
> statistics 10000;
> WARNING: lowering statistics target to 1000
> ALTER TABLE
> It seems there is no way to make it close to being correct...
> If any developer is curious and wants the data, I do have a compressed
> postgres dump of this table, it's around 125MB.
> Cheers
> Andrea
> postgis-users mailing list
() ASCII Ribbon Campaign
/\ Keep it simple!
