[postgis-users] projection management
Ken Boss
Ken.Boss at dnr.state.mn.us
Wed Mar 28 07:33:36 PDT 2007
>>> On 3/27/2007 at 10:53 PM, in message
<436524.29481.qm at web33212.mail.mud.yahoo.com>, Brent Wood <pcreso at pcreso.com>
wrote:
>> Thanks for the reply, that clarifies matters nicely. I think I'm
>> understanding also that setsrid(the_geom, the_srid) rolls that srid
>> right into the binary representation of the geometry. I wonder if it
>> might be desirable/possible in a future version, then, to have
>> astext(the_geom) output the srid along with the text representation of
>> the geometry.
> I believe WKT is defined by the OGC, as part of the SFS spec that PostGIS
> complies with. EWKT was created to address this limitation of the WKT format.
> It is not likely that OGC will revise the SFS/WKT spec, so it is also unlikely
> that PostGIS will modify the string returned by WKT.
> So if you require a SRID in the output, use EWKT instead of WKT.
> Standards are usually a good thing :-)
Fully agreed. As a postgis newbie, I was as yet unfamiliar with the wonders of EWKT and EWKB.
Hats off to the Refractions folks for a nice job of covering both user needs and standards conformance,
and thanks to the list for the education.
--Ken
> Cheers
> Brent
> postgis-users mailing list
