[postgis-users] Re: [postgis-devel] Several R-Trees
Nicolas Ribot
nicky666 at gmail.com
Thu Mar 29 07:14:43 PDT 2007
On 3/29/07, Leticia <lgomez at itba.edu.ar> wrote:
> The analyze plan shows me that it decides to use only one of these two
> indexes, instead of using a Spatial Join
> I have built two R-trees indexes and run analyze over the tables:
> Create index idxrivers2000 on rivers2000 using gist (geometry
> gist_geometry_ops)
> Create index idxcities2000 on cities2000 using gist (geometry
> gist_geometry_ops)
> Then I query
> explain
> SELECT COUNT(*)
> FROM usa_rivers2000, usa_cities2000
> WHERE usa_rivers2000.geometry && usa_cities2000.geometry AND
> intersects(usa_rivers2000.geometry, usa_cities2000.geometry )
> I obtain
> "Aggregate (cost=18.08..18.09 rows=1 width=0)"
> " -> Nested Loop (cost=0.00..17.97 rows=41 width=0)"
> " Join Filter: intersects(usa_rivers2000.geometry,
> usa_cities2000.geometry)"
> " -> Seq Scan on usa_rivers2000 (cost=0.00..1.17 rows=17
> width=130)"
> " -> Index Scan using idxcities2000 on usa_cities2000
> (cost=0.00..0.97 rows=1 width=112)"
> " Index Cond: (usa_rivers2000.geometry &&
> " Filter: (usa_rivers2000.geometry && usa_cities2000.geometry)"
> Can I force the optimizer to use the Two indexes ?
You can disable sequential scan for the time of the query:
set enable_seqscan = off;
to force optimizer to use index, then reset the sequential scan:
set enable_seqscan = on;
Nicolas
