[postgis-users] Creating an ID field in a view
Jose Gomez-Dans
jgomezdans at gmail.com
Thu Mar 29 11:37:42 PDT 2007
Hi Mark,
On 3/29/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> > for my own purposes), I need to create an unique field per feature. Is
> > there some function which will add this field and populate it
> > accordingly? I am not interested in its value, only in the fact that
> > it has to be unique for each feature in the view.
> If you don't care if the value changes each time you run the query,
> simply create a sequence and reference it in your SELECT, e.g.
Mmmm, this would be OK for just throwing the data into QGIS to view
it. However, I would also like to do some work with it, so the value
would need to be "static" (i.e., it should not change when I run the
query). However, the tip is useful :)
Cheers,
Jose
