[postgis-users] Request from Narayanan
Tim Bowden tim.bowden at westnet.com.au
Thu Mar 29 22:16:03 PDT 2007
On Fri, 2007-03-30 at 10:03 +0530, narayanan rm wrote:
> Dear Friends,
> I need a small help from you , i want to install the postgis-1.2.1 in
> Fedoara 4, I have downloaded the tar file from postgis refraction, and
> configured in /usr/local/postgis1.2.1 it gives okay,
> then i make, make install, after that i could not createlang , and
> further install it please advice me how to solve the issues
You can't createlang as root.  Either, su - postgres (or whatever user
postgres runs as) and createlang or create a superuser with your
username, and then try createlang.
HTH,
Tim Bowden
> Here is the report i obtained
> With regards
> RM Narayanan
> [root at localhost postgis-1.2.1]# ./configure
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking whether ln -s works... yes
> checking for iconv_open in -liconv... no
> checking for libiconv_open in -liconv... no
> checking for iconv_open in -lc... yes
> checking how to run the C preprocessor... gcc -E
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking for pg_config... /usr/bin/pg_config
> checking for geos-config... /usr/local/bin/geos-config
> checking for proj... /usr/local/bin/proj
> checking for flex... /usr/bin/flex
> checking for dllwrap... no
> checking for dlltool... no
> checking for bison... bison -y
> checking for perl... /usr/bin/perl
> checking for xsltproc... /usr/bin/xsltproc
> checking for pdfxmltex... /usr/bin/pdfxmltex
> checking for db2pdf... /usr/bin/db2pdf
> checking for jw... /usr/bin/jw
> checking which template to use... linux
> configure: creating ./config.status
> config.status: creating Makefile.config
> config.status: WARNING:  Makefile.config.in seems to ignore the
> --datarootdir setting
> config.status: creating config.h
> config.status: config.h is unchanged
>  SUMMARY
>  HOST_OS: linux-gnu
>    PGSQL: /usr/bin/pg_config
>     GEOS: /usr/local/bin/geos-config (with C-API)
>           (ldflags: -L/usr/local/lib)
>     PROJ: prefix=/usr/local libdir=/usr/local/lib
>    ICONV: 1
>  PORTNAME: linux
>    PREFIX: /usr
>   EPREFIX: ${prefix}
>       DOC: /usr/share/doc/postgresql/contrib
>      DATA: ${datarootdir}
>       MAN: ${datarootdir}/man
>       BIN: /usr/bin
>       EXT: /usr/lib/pgsql (\$$libdir)
> [root at localhost postgis-1.2.1]# make
> make -C lwgeom
> make[1]: Entering directory `/usr/local/postgis-1.2.1/lwgeom'
> cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
> 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.2:g;s:@POSTGIS_VERSION@:1.2
> USE_GEOS=1 USE_PROJ=1
> USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.2.1:g;s/@POSTGIS_BUILD_DATE@/2007-03-30
> 03:55:15/g' | grep -v '^#' > ../lwpostgis.sql
> 's#@MODULE_FILENAME@#/usr/local/postgis-1.2.1/lwgeom/liblwgeom.so.1.2#g;s#@POSTGIS_VERSION@#1.2
> USE_STATS=1#g;s#@POSTGIS_SCRIPTS_VERSION@#1.2.1#g;s/@POSTGIS_BUILD_DATE@/2007-03-30
> 03:55:15/g' | grep -v '^#' > ../regress/lwpostgis.sql
> /usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
> ../lwpostgis_upgrade.sql
> gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.2.1"'
> -DPOSTGIS_VERSION='"1.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
> -DPOSTGIS_SCRIPTS_VERSION='"1.2.1"' -DPOSTGIS_BUILD_DATE='"2007-03-30
> 03:55:15"' -I/usr/local/include -DUSE_PROJ
> -I/usr/include/pgsql/server -DAUTOCACHE_BBOX=1  -DUSE_STATS -Wall -g
> -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include     -c -o
> measures.o measures.c
> box2d.o box2d.c
> ptarray.o ptarray.c
> lwgeom_api.o lwgeom_api.c
> lwgeom.o lwgeom.c
> lwpoint.o lwpoint.c
> lwline.o lwline.c
> lwpoly.o lwpoly.c
> lwmpoint.o lwmpoint.c
> lwmline.o lwmline.c
> lwmpoly.o lwmpoly.c
> lwcollection.o lwcollection.c
> wktunparse.o wktunparse.c
> lwgparse.o lwgparse.c
> wktparse.tab.o wktparse.tab.c
> lex.yy.o lex.yy.c
> lex.yy.c:4023: warning: 'yyunput' defined but not used
> vsprintf.o vsprintf.c
> liblwgeom.o liblwgeom.c
> lwgeom_pg.o lwgeom_pg.c
> lwgeom_debug.o lwgeom_debug.c
> lwgeom_spheroid.o lwgeom_spheroid.c
> lwgeom_ogc.o lwgeom_ogc.c
> lwgeom_functions_analytic.o lwgeom_functions_analytic.c
> lwgeom_geos_c.o lwgeom_geos_c.c
> lwgeom_inout.o lwgeom_inout.c
> lwgeom_estimate.o lwgeom_estimate.c
> lwgeom_functions_basic.o lwgeom_functions_basic.c
> lwgeom_gist.o lwgeom_gist.c
> lwgeom_btree.o lwgeom_btree.c
> lwgeom_transform.o lwgeom_transform.c
> stringBuffer.o stringBuffer.c
> lwgeom_box.o lwgeom_box.c
> lwgeom_box3d.o lwgeom_box3d.c
> lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
> lwgeom_chip.o lwgeom_chip.c
> lwgeom_svg.o lwgeom_svg.c
> lwgeom_gml.o lwgeom_gml.c
> lwgeom_kml.o lwgeom_kml.c
> lwgeom_triggers.o lwgeom_triggers.c
> lwgeom_dump.o lwgeom_dump.c
> lwgeom_functions_lrs.o lwgeom_functions_lrs.c
> long_xact.o long_xact.c
> lwcurve.o lwcurve.c
> lwcompound.o lwcompound.c
> lwcurvepoly.o lwcurvepoly.c
> lwmcurve.o lwmcurve.c
> lwmsurface.o lwmsurface.c
> lwgeom_sqlmm.o lwgeom_sqlmm.c
> -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include   -shared
> -Wl,-soname,liblwgeom.so.1  measures.o box2d.o ptarray.o lwgeom_api.o
> lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
> lwcollection.o   wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o
> vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o
> lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos_c.o
> lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o
> lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o
> lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o
> lwgeom_svg.o lwgeom_gml.o lwgeom_kml.o lwgeom_triggers.o lwgeom_dump.o
> lwgeom_functions_lrs.o long_xact.o lwcurve.o lwcompound.o
> lwcurvepoly.o lwmcurve.o lwmsurface.o lwgeom_sqlmm.o  -shared
> -L/usr/local/lib -lgeos_c -L/usr/local/lib -lproj -o liblwgeom.so.1.2
> rm -f liblwgeom.so.1
> ln -s liblwgeom.so.1.2 liblwgeom.so.1
> rm -f liblwgeom.so
> make[1]: Leaving directory `/usr/local/postgis-1.2.1/lwgeom'
> make -C loader
> make[1]: Entering directory `/usr/local/postgis-1.2.1/loader'
> gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80
> -DPOSTGIS_VERSION='"1.2.1"'   -c -o shpopen.o shpopen.c
> shpopen.c:176: warning: 'rcsid' defined but not used
> -DPOSTGIS_VERSION='"1.2.1"'   -c -o dbfopen.o dbfopen.c
> dbfopen.c:206: warning: 'rcsid' defined but not used
> -DPOSTGIS_VERSION='"1.2.1"'   -c -o getopt.o getopt.cgcc -g -Wall -I..
> -DUSE_ICONV -DUSE_VERSION=80 -DPOSTGIS_VERSION='"1.2.1"'   -c -o
> shp2pgsql.o shp2pgsql.c
> -DPOSTGIS_VERSION='"1.2.1"' shpopen.o dbfopen.o getopt.o shp2pgsql.o
> -o shp2pgsql
> -DPOSTGIS_VERSION='"1.2.1"' -I/usr/include -c pgsql2shp.c
> -DPOSTGIS_VERSION='"1.2.1"'   -c -o PQunescapeBytea.o
> PQunescapeBytea.c
> PQunescapeBytea.o pgsql2shp.o  -L/usr/lib -lpq  -o pgsql2shp
> make[1]: Leaving directory `/usr/local/postgis-1.2.1/loader'
> make -C utils
> make[1]: Entering directory `/usr/local/postgis-1.2.1/utils'
> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
> profile_intersects.pl test_estimation.pl test_joinestimation.pl
> make[1]: Leaving directory `/usr/local/postgis-1.2.1/utils'
> make -C extras/template_gis
> make[1]: Entering directory `/usr/local/postgis-1.2.1/extras/template_gis'
> cat createdb.postgis.in | sed -e s:@bindir@:/usr/bin:g -e
> s:@datadir@:/usr/share:g -e s:@prefix@:/usr:g -e s:@SONAME@:1:g >
> createdb.postgis;  cat mktemplate_gis.in | sed -e
> s:@bindir@:/usr/bin:g -e s:@datadir@:/usr/share:g -e s:@prefix@:/usr:g
> -e s:@SONAME@:1:g > mktemplate_gis;  cat mktemplate_gis.sh.in | sed -e
> -e s:@SONAME@:1:g > mktemplate_gis.sh;  cat postgis_env.sh.in | sed -e
> -e s:@SONAME@:1:g > postgis_env.sh;  cat postgres_lib.sh.in | sed -e
> -e s:@SONAME@:1:g > postgres_lib.sh;  cat rmtemplate_gis.in | sed -e
> -e s:@SONAME@:1:g > rmtemplate_gis;  cat rmtemplate_gis.sh.in | sed -e
> -e s:@SONAME@:1:g > rmtemplate_gis.sh;
> make[1]: Leaving directory `/usr/local/postgis-1.2.1/extras/template_gis'
> [root at localhost postgis-1.2.1]# make install
> make -C lwgeom
> make[1]: Nothing to be done for `all'.
> make -C loader
> make -C utils
> make -C lwgeom install
> /usr/local/postgis-1.2.1/install-sh -c -m 755 liblwgeom.so.1.2
> /usr/lib/pgsql/liblwgeom.so.1.2
> cd /usr/lib/pgsql && \
> rm -f liblwgeom.so.1 && \
> rm -f liblwgeom.so && \
> /usr/local/postgis-1.2.1/install-sh -c -m 644 ../lwpostgis.sql
> /usr/share/lwpostgis.sql
> /usr/local/postgis-1.2.1/install-sh -c -m 644 ../lwpostgis_upgrade.sql
> /usr/share/lwpostgis_upgrade.sql
> /usr/local/postgis-1.2.1/install-sh -c -m 644 ../spatial_ref_sys.sql
> /usr/share/spatial_ref_sys.sql
> make -C loader install
> /usr/local/postgis-1.2.1/install-sh -c -m 755 pgsql2shp /usr/bin/pgsql2shp
> /usr/local/postgis-1.2.1/install-sh -c -m 755 shp2pgsql /usr/bin/shp2pgsql
> make -C extras/template_gis install
> /usr/local/postgis-1.2.1/install-sh -c -m 755 createdb.postgis
> /usr/bin/createdb.postgis;  /usr/local/postgis-1.2.1/install-sh -c -m
> 755 mktemplate_gis /usr/bin/mktemplate_gis;
> /usr/local/postgis-1.2.1/install-sh -c -m 755 mktemplate_gis.sh
> /usr/bin/mktemplate_gis.sh;  /usr/local/postgis-1.2.1/install-sh -c -m
> 755 postgis_env.sh /usr/bin/postgis_env.sh;
> /usr/local/postgis-1.2.1/install-sh -c -m 755 postgres_lib.sh
> /usr/bin/postgres_lib.sh;  /usr/local/postgis-1.2.1/install-sh -c -m
> 755 rmtemplate_gis /usr/bin/rmtemplate_gis;
> /usr/local/postgis-1.2.1/install-sh -c -m 755 rmtemplate_gis.sh
> /usr/bin/rmtemplate_gis.sh;
> rm -f /usr/bin/mktemplate_gis; ln -s /usr/bin/mktemplate_gis /usr/bin;
>  rm -f /usr/bin/rmtemplate_gis; ln -s /usr/bin/rmtemplate_gis
> /usr/bin;  rm -f /usr/bin/createdb.postgis; ln -s
> /usr/bin/createdb.postgis /usr/bin;
> cp profile /etc/default/postgis
> rm -f /usr/bin/profile
> /usr/local/postgis-1.2.1/install-sh -c -m 644 createdb.postgis.1
> /usr/share/man/man1/createdb.postgis.1;
> /usr/local/postgis-1.2.1/install-sh -c -m 644 mktemplate_gis.1
> /usr/share/man/man1/mktemplate_gis.1;
> /usr/local/postgis-1.2.1/install-sh -c -m 644 rmtemplate_gis.1
> /usr/share/man/man1/rmtemplate_gis.1;
> [root at localhost postgis-1.2.1]# createlang plpgsql postgis
> createlang: language installation failed: ERROR:  permission denied
> for language c
> [root at localhost postgis-1.2.1]# make check
> make -C regress test
> make[1]: Entering directory `/usr/local/postgis-1.2.1/regress'
> psql: FATAL:  permission denied to set parameter "lc_messages"
> Creating spatial db postgis_reg
> createdb: could not connect to database template1: FATAL:  permission
> createlang: could not connect to database postgis_reg: FATAL:
> database "postgis_reg" does not existpsql: FATAL:  database
>  Something went wrong (no postgis installed in postgis_reg).
>  For details, check /tmp/pgis_reg_8466/regress_log
> make[1]: *** [test] Error 1
> make[1]: Leaving directory `/usr/local/postgis-1.2.1/regress'
> make: *** [check] Error 2
> postgis-users mailing list
